Kicker comp Vrs
Old May 30, 2005 | 07:57 AM
99NJMAX's Avatar
Kicker comp Vrs
My cousin is giving me his 2 10" kicker comp vrs. Can anyone recomend me a cheap but decent amp to power them? and should I look into a good wiring kit for when i switch over to something better to save the time of running everything over again?
Old May 30, 2005 | 11:23 AM
Golden Ice's Avatar
get about 25 feet of 1/0 cable, 20 should be enough to run from the battery to the trunk, but getting 25 gives you some extra to play around with. I'd also pick up about 3-6 ft of another color for a ground. Running the same color works fine, as long as you dont screw up and wire it backwards...you can more than likely find somthing, even a distro block, to adapt it to smaller wiring in the trunk if you need, running 1/0 gives you plenty of headroom in the future for all the system you'll really wanna put in your max. To be realistic, you could run just 0 ga, but if you can afford it, run 1/0 so you dont have to worry about upgrading it later on. I'd buy everything separately, and stay away from a kit...unless you wanna buy a kit AND RCAs, since most rcas included in wiring kits suck.
This is a good choice for strand count/price/shipping, although you might have to ask for another color if you want somthing other than blue.
As for RCAs, there are a lot of choices. Stinger is decent, Monster THX certified is good, making your own if you do it right works well too, but its not a good idea to make your own if you're not pretty proficient with soldering.
As for a cheap/decent amp, you could try a Profile california series mono amp, although they're known for overstating their power output.
Old May 30, 2005 | 12:42 PM
seventy5impala's Avatar
well im only running 4 guage, i thought 0 would just be over kill...im running 8-900 watts rms.....so 4 gauge is plenty... and my only upgrade i might do is adding another 500 watts.... and id still consider myself safe with the 4 guage(and if not power wire was the asiest of my wires to run).....but as far as an amp for those woofers...150-250 watts RMS per channel id think would push them nice a kicker KX400.1 or something along those lines...speaking of , whats there ohms any idea? im an ebayer when it comes too wanting a cheaper good amp or anything most of my system is off ebay lol....perhaps one of these other guys know of a store cheap good amp...
Old May 30, 2005 | 03:42 PM
Polecat's Avatar
if you get two DVC 2 ohm subs, the Kicker KX400.1 will do fine. It will do roughly 425-500 watts mono into a 2 ohm load.
Old May 30, 2005 | 03:49 PM
slickrick's Avatar
glad to see you could make it polecat!
Old May 31, 2005 | 09:37 PM
Polecat's Avatar
thanks man! good to run onto you here too
Old Jun 1, 2005 | 02:05 PM
MannyNJ2k2max's Avatar
Welcome to the board Tracy Nice to have an orger like yourself, again congrats on the 6th gen...(3.5max6spd on 'caraudio')
BTW I'll be sending my zr360 to you soon...
stevesmax
Dec 17, 2020 11:57 AM
Soon2BMaxed
Feb 23, 2001 10:55 PM
Nismo
Feb 22, 2001 09:25 AM
MaxRod33
Nov 23, 2000 10:01 PM
