Sirius Question
Old Jun 13, 2005 | 05:15 AM
missjane's Avatar
Sirius Question
OK, I am ready to get my OEM receiver and get my Sirius all hooked up. I am looking at Grubbs Performance. Which antenna should I get? Any difference? There is an OEM reciever on eBay that I was looking at, too.....6 mos old. But, as much as I have bought and sold on eBay, this is one item I am a bit hesitant to bid on.
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
Any thoughts on all of the above?
Jane
Old Jun 13, 2005 | 07:56 AM
NismoMax80's Avatar
SuPeRmOd
get the Mini Terk. Unless you don't care about size, just get the cheapest you can find. I bought mine from Crutchfield through Amazon.com for $40 while it was backordered.
I would not buy that off eBay. How do you know it will work on the Max? As far as I know, the Tuners (receivers) are different. Get it from Grubbs. You also get 3 free months and $285 is a good price. Install is simple. You may need to get a splitter to connect the antenna, so ask Grubbs if it comes with it.
Old Jun 13, 2005 | 08:18 AM
Yanksrule57's Avatar
OEM Antenna Kit
Any reason you don't want to use the factory antenna kit? I bought that at the same time as my OEM receiver and it works great. I had it mounted on the trunk lid and think it looks fine there.
Old Jun 13, 2005 | 08:23 AM
NismoMax80's Avatar
SuPeRmOd
only thing i have against it is that it's huge. The mini is a lot smaller. So how did you mount it on the trunk? b/c the aluminum trunk lid is non-metalic.
Old Jun 13, 2005 | 09:05 AM
Defib's Avatar
I used the "factory" unit and mounted it at the rear of the roof as suggested. I had it painted to match the car (spirited bronze). It is a little big, but the paint kind of hides it!
Old Jun 15, 2005 | 01:10 PM
95Max's Avatar
Go for the Sigma. It is an inside antenna that mounts on the glass.
Old Jun 17, 2005 | 02:14 PM
tmcnelia's Avatar
Sirius Tuner
What make tuner do I need to purchase for my 04 Max? Also, I have the Bose package and wanted to know the maker of the radio.
Old Jun 20, 2005 | 05:42 AM
95Max's Avatar
The radio and the Sat receiver is made by clarion for Nissan. If you want to use the factory contols for the Sat radio you will need to get the Nissan unit.
Old Jun 20, 2005 | 06:57 AM
phathawaiian's Avatar
I called my dealership about the sirrus install, they said they could mount the antenna inside the car now under the dash and it would work fine....might wanna ask them.
Old Jun 20, 2005 | 09:59 AM
95Max's Avatar
Yes they can put the antenna in the car. It is called the Sigma. It goes at the top of the windshield behind the rearview, not under the dash. If you put the antenna under the dash you will not get the signal as there is no way the antenna could "see" the satellite.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
