95 BOSE Speakers
Old Jun 24, 2005 | 07:46 AM
acmax95's Avatar
95 BOSE Speakers
I have a 95 GLE with BOSE. Ive got an aftermarket HU installed. I am going to replace all the speakers with Kicker 6.5's.
Here's the problem. When i went to replace the speakers i found those speaker connections with the plugs. Can i cut those plugs off and use the stock wires? Or do i need to run new wiring for the speakers? Also if i can cut the plugs and use the wires which wires do i use to connect to the speakers?
I looked at the faqs and looked at the MT 1995-97 wire thing and couldn't tell from there. Also i am disposing of the amps connected to the speakers.
Thanks a lot
Old Jun 24, 2005 | 09:28 AM
kpr10is's Avatar
There are 4 wires going to the amp at each speaker, theres power, ground, (+) speaker, and (-) speaker. Tap into the speaker wires before the bose amp, and use a spare 6" of speaker wire to go to the speaker. I dont know the colors offhand, when im doing these installs I leave the deck out so I can use the aftermarket wiring harness, plug it in and look at which colors are which. So if nobody else responds with colors you can always do that.
-kevin
Old Jun 24, 2005 | 10:07 AM
ionpcs's Avatar
If you can't find the wiring diagram anywhere else, I'll tell you the colors to use later tonight.
I think Brown was Negative and Purple was positive on the right side though.
magiconthetire
Oct 26, 2015 09:03 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
