Door Speaker Removal..
Old Jun 26, 2005 | 06:26 PM
Pit5Bull's Avatar
Is there anybody out there that has instructions on removing the door speakers (front & rear) on a 5th Gen? Need it ASAP!!!
Thanks Mucho
Old Jun 26, 2005 | 07:34 PM
audiblepiphany's Avatar
http://www.carstereoremoval.com/htm/...xima00_03P.htm
^ the quickest way to get those directions...after paying, it will redirect you to the site with the directions. Granted its pointless to spend money on the diagrams individually, its quick access.
Old Jun 26, 2005 | 07:47 PM
merovi's Avatar
dont pay for that info. u just remove the trim in the door that holds the switches by removeing the screw in the dish. then pop out the tap in top close to the hinge and remove that screw. then remove the plastic trim around the door handle. grab at the bottom of the door and it will pull away. just tabs holding it on after those 2 screws
Old Jun 26, 2005 | 07:52 PM
seventy5impala's Avatar
un screw the screw under the cap in the pull hole on the door, where your fingers go when shutting the door. Around the door handle remove the plastic trim peice carefully, and also pry up the window control trim peice, might beh ard at first but ill come......unplug it, then feel around the bottom of the door panel there will be about 2-3 inch space so u can fit some fingers in and use that as a startin point too start poping the clips, go one was at a time up too the window....then once all clips have been poped out lift door panel over window seat and remove........ used on all for doors....... then u have access to your speakers, which is just held with some screws...good luck and be gental
Old Jun 26, 2005 | 08:33 PM
Pit5Bull's Avatar
Thanks guys! I needed this information now that I've run the power cable from the battery to the trunk (took the main fuse out until I decide where the amps, distro blocks & ground will go in the trunk).
You guys are the best!
Old Jun 27, 2005 | 03:05 PM
merovi's Avatar
best bet is to fit the amps on the back seats. but keep in mind they have to be low because of the round clearence area on the back panel behind the seat. also dont forget that our seats are 2 pieces. i have to put both of mine down because i have an amp on 1 and the distro block and cap on the other and forgot to give it more slack. a good grounding point that i use is right under the carpet flaps where the back of the seats meet the trunk.
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
