viper 530T... window control module
Old Jun 27, 2005 | 04:47 PM
f550maranello2's Avatar
where on earth is the window control module located? im in the car right now and i cant find it.. do you go after the master switch or not?
Old Jun 27, 2005 | 04:48 PM
kpr10is's Avatar
Gotta run wires into the door to each switch.
Old Jun 27, 2005 | 04:52 PM
ok is the module in the door switch or not. and im assuming u wire the 530t between the switch and the motor right??
Old Jun 27, 2005 | 05:02 PM
bump need help fast............
Old Jun 27, 2005 | 07:49 PM
well this sucks it works but now the window switches dont and neither do the door locks wtf? Don help me out man...lol
Old Jun 27, 2005 | 08:16 PM
Pearl96Max's Avatar
I tend to get a bit irritable
You gotta cut each wire right at each switch. The 'module' is located inside each switch.
Old Jun 27, 2005 | 08:22 PM
ok that makes a little sense... thats what i did but now the locks and the windows dont work when i press the switch..
Old Jun 27, 2005 | 08:34 PM
Pearl96Max's Avatar
LF Window up/dn blu/red - blu/blk A in LF door at switch
RF Window up/dn blu/red - blu/blk A in RF door at switch
LR Window up/dn blu/red - blu/blk A in LR door at switch
RR Window up/dn blu/red - blu/blk A in RR door at switch
Old Jun 28, 2005 | 09:35 AM
hey Don i did what u suggested... but now the windows roll all the way up or all the way down. cant get them to stay in one position when i use then from inside... ( its one touch opperation both ways)
Old Jun 28, 2005 | 09:36 AM
Pearl96Max's Avatar
Thats one touch. Just press the opposite direction for them to stop moving.
Old Jun 28, 2005 | 09:37 AM
they dont... when i do that they just stop and go back up or down....( both driver and passanger) any suggestions Don?
Old Jun 28, 2005 | 10:48 AM
alright so far it works like this....
the driver side and passanger side windows work one touch.. when i want to open the windows they go all the way up or all the way down... i cant get a window to be half way open...wtf?
i want this thing to work just like factory.. but i want to roll the windows up and down with the remote!!! why on earth does this not want to work corrrectly? Its wired up right?!!?!?!?!?!
Old Jun 28, 2005 | 12:28 PM
bump............... anybody?
Old Jun 28, 2005 | 01:17 PM
filtor1's Avatar
Same thing happens to me. I have to give the window trigger a quick pull back up to get it to stop half way. You can actually stop it anywhere. If you pull all the way up, the window will return to closed.
Old Jun 28, 2005 | 01:19 PM
thats stupid... is this really how its supposed to work... i thought that it worked like factory windows except you can roll them up with the remote and close then also!!!
Old Jun 28, 2005 | 01:52 PM
filtor1's Avatar
This is just my understading based upon how mine works and was programmed. You cannot roll the windows up with the 530T. You can roll them down and if it has been 30 seconds since you last used the window feature, they will roll up with the arming of the unit. The windows can be rolled down im incriments if programmed to do so. I believe the default setting is one touch. I installed 2 530T's, one for each set of windows.
Old Jun 28, 2005 | 03:57 PM
kpr10is's Avatar
Yes. Do you really want to have to hold the remote buttons down while the windows go down? That sucks. One touch is way better. Nonetheless, you should be able to stop the windows from moving by touching them in the opposite direction, and if you cant then something is wired wrong.
Old Jun 28, 2005 | 09:43 PM
does anybody else have any opinions on this module?
Fbana41
Aug 29, 2016 12:18 PM
knight_yyz
Nov 1, 2015 01:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
