INTERIOR OVERHAUL PROJECT II - Fiberglassing a 4-Din Center Console
Old Jul 20, 2005 | 07:38 PM
  #81
AscendantMax's Avatar
looking good so far man
btw...your avatar brings back A LOT of memories at the arcade
Old Jul 20, 2005 | 07:49 PM
  #82
2 Da Max's Avatar
yes it does.. i love street fighter 2, but not as much as i love street fighter vs xmen. lol you could do the crasy 130 hit combos
Old Jul 22, 2005 | 08:48 AM
  #83
quiksand's Avatar
Shin Akuma is the man. Memories, I play all of the old Street Fighter Arcade games on my Modded Xbox. Those along with my NES, Genesis, Sega MAster System & SNES games get more play than my Xbox games.
Old Jul 22, 2005 | 09:26 AM
  #84
MannyNJ2k2max's Avatar
interior is going to look sick!!! looks great so far...
Old Jul 23, 2005 | 12:02 PM
  #85
Alphaq55's Avatar
Looking good man
Old Jul 23, 2005 | 12:18 PM
  #86
Metal Maxima's Avatar
SHIFT_om nom nom nom
Thanks for all the support, everyone! I made the first cut into the cluster today for the climate control today. It was, ummm...interesting to say the least. I should have some pics up on Monday night, my schedule is bonkers for the next few days.
Old Jul 27, 2005 | 07:20 AM
  #87
In spite of being bogged down with 12-hour shifts, I managed to get some work done on this thing. I first sanded the whole unit down with the typical 60, 150, 220, 500, and 800-grit papers to give it a baby-smooth finish. I also filled in all the holes and leveled all of the transistion lines with body filler and glazing putty. Don't mind how it looks at the top, if you look close enough yoiu can see the black fleece underneath.
The I cut the climate control face and made the cutout for the unit. The picture is a little off-center, so the unit does not appear fully lined up, but in reality, it's pretty darn close, although not perfect. I had to starts taking pictures inside since the camera lens fogs up not 0.01 seconds after I walked ouitside.
Old Jul 27, 2005 | 07:23 AM
  #88
Igor911's Avatar
what did you use to do the cutting?
Old Jul 27, 2005 | 07:26 AM
  #89
Big_Ham's Avatar
MaximaFreak
Man, you're at Rowan University? That's where I graduated from. Easiest school in SJ! (unless you're an engineering major).
BTW ... nice work ... coming along ...
Old Jul 27, 2005 | 07:31 AM
  #90
I used a Dremel with a fiber-reinforced disc since I found these have a much longer cutting life than the regular discs. They also don't weaken as much when they heat up from the cutting...fortunatley, I've only had one of these break off and send a heated shard of death into my face.
Which I was. Chemical engineering...ranked 3rd in the country for public engineering...and no - IT WAS NOT EASY. While I was taking my diff eq. course I downloaded an old test from the same course at U Penn...imagine my fury as their test was EASIER. It's no joke there, but I have a good job now thanks to it. But I it take it you're close to Rowan?
Old Jul 27, 2005 | 07:32 AM
  #91
djfrestyl's Avatar
Suspension Yoda
Looks good Dan-
Just a thought. I remember when Don helped me with my failed fiberglassing attempt we had an issue when the rubber ring on the inside of the shifter trim went back on. Your body filler seems to be at the top edge of where the ring will go. Have you tried to see if that ring will get back on? You may have to sand it there to avoid cutting the ring, like we just did.
Old Jul 27, 2005 | 07:33 AM
  #92
Igor911's Avatar
I bought a Dremel kit a while back from HomeDepot. Do you know how to make a straight cut with the dremel? Do they sell some sort-of attachment that guides the cut?
Old Jul 27, 2005 | 07:34 AM
  #93
Thanks, Nilesh! Not quite sure what you mean by he rubber ring...do you mean the flange of the shifter boot that attaches to the shifter opening? I hope I am not going to have another issue to face, here!
Old Jul 27, 2005 | 07:36 AM
  #94
djfrestyl's Avatar
Suspension Yoda
Gah! forgot you weren't automatic. We have a rubber ring that lines the inner circle of the shifter trim. You guys have a flange that will connect the leather boot to the inner ring. I guess, make sure the filler isnt in the way of the flange popping back in!
Old Jul 27, 2005 | 07:40 AM
  #95
Big_Ham's Avatar
MaximaFreak
Actually, no. My parents are, but I moved to Tampa 5 years ago. I highly reccommend it.
I lived right next door in Pitman one year and those dumpy apartments on Mullica Hill Rd. for two years. Can't say I miss Assboro
Old Jul 27, 2005 | 07:41 AM
  #96
djfrestyl's Avatar
Suspension Yoda
I've got some good friends in Mullica Hill. Dan how close are u to there?
BAHAHAHA Assboro.
  #97
Well, I have tried a number of things.
This multi-purpose cutting kit is supposed to work like a router, but it does not really cut worth a damn. All ot does it heat the crap out of the bit. I don't recommend it for cutting fiberglass.
The mini-saw attachment also sucked. This was supposed to allow me to get nice and smooth cuts, but it did not work out too well, either. The blade is really short and did not work out too well, either.
These cut-off wheels are teh B0mz0r. My weapon of choice. The blades are VERY durable and large, so you can cut through thicker surfaces (such as in my case where I have 2 to 3 layers to cut through. It's hard to make a precise cut at times, but that's what body filler is for.
I would imagine this diamond wheel is very good as well, but the blades tend to get SUPER hot from horizontal friction when cutting and will cause a blade to break every now and again. The fiber discs above are $7/4 discs whereas a single diamond wheel is $14. I feel better knwoing that a busted disc is only running me $1.75...not $14.
Old Jul 27, 2005 | 07:45 AM
  #98
I've got some good friends in Mullica Hill. Dan how close are u to there? BAHAHAHA Assboro.
About 40 minutes...and yeah, when I had to venture outside of Rowan's shiny Engineering building I did find myself in the heart of exactly that - Assboro. What a crap town.
Yeah, since I am a manny driver I have some clips it attaches to, but there is some body filler over the one set of clips, so I might have some trouble down the road! *knocks on wood*
Old Jul 27, 2005 | 07:52 AM
  #99
djfrestyl's Avatar
Suspension Yoda
Well better to sand it down now before you forget (if you forget) and paint it.
Old Jul 27, 2005 | 11:40 AM
  #100
Trevmister1610's Avatar
it looks very good, i cant wait to see more pics, this is the first i have heard of mixing the hardner and body filler together, when i did mine i just used straight up body filler, what is the bennifets to mixing the hardner to it?
Old Jul 27, 2005 | 11:52 AM
  #101
I think you might have mixed your words a bit here. You ALWAYS mix hardener to body filler, otherwise it would never harden. I think you are referring to mixing resin & body filler? When you mix the two you get a pourable mixture that will create a smooth surface over the peice, fill in most of the holes and gaps, and is MUCH easier to sand than fiberglass.
Old Jul 27, 2005 | 01:31 PM
  #102
TJ_Max's Avatar
Paradox Systems Vendor
this is like a movie, im dying to see the end result...
Old Jul 27, 2005 | 06:40 PM
  #103
Haha, I like that. I should have a pretty ample amount of time on Saturday to work on this, with any luck it should be 90% done.
Old Jul 28, 2005 | 03:00 AM
  #104
ChromeSE5's Avatar
You can mix fiberglass resin and body filler? I never knew that. Would it be regular resin or resin with its hardner and body filler with its hardner?
Old Jul 28, 2005 | 02:48 PM
  #105
Maximeltman's Avatar
Damn I sure am late to comment on this thread of your's Dan, But you da man! I can't wait to see the final pic(s)!!
Old Jul 30, 2005 | 10:15 AM
  #106
Ok, your mix would consist of:
50% Resin + appropriate amount of MEKP - mix thoroughly prior to adding the body filler
50% Body filler
Old Jul 30, 2005 | 10:20 AM
  #107
Alright! I am damned determined to get the cuts done this weekend after spending every waking moment at work this past week. Here we can see some pics of the climate control face attached with body filler and sanded. There are a few rough spots which will require some attention later on.
and now for a close-up.
Old Jul 30, 2005 | 10:24 AM
  #108
I have to give credit to Nilesh for riding me, I mean motivating me, about flush-mounting the HU, so here's how it came out! I will have to usesome Tiger Hair to fill the one side in since I sanded down to far (40-grit = paper saw, seriously ). But I must say that it looks hella good mounted this way.
and a shot from the top. It's a bit contoured, but only if viewed from this angle, so I can live with that.
Old Jul 30, 2005 | 10:51 AM
  #109
djfrestyl's Avatar
Suspension Yoda
Sah-weeeet.
That is all, carry on por favor.
Old Jul 30, 2005 | 08:35 PM
  #110
Whitebread's Avatar
Very nice job man
Old Jul 31, 2005 | 09:34 PM
  #111
2 Da Max's Avatar
looks good, are you mounting a tv at the top of the hu? or are the vents going there? btw i thought an audiophile like you would have an eclipse hu...
Old Jul 31, 2005 | 09:59 PM
  #112
damn, that flush mount HU does look damn good...
Old Aug 1, 2005 | 03:49 AM
  #113
Thanks! The screen will go above the HU, which will sit below the air vents.
I was seriously considering an Eclipse HU, but at the time I was shopping for HUs they did not have a unit that was Sirius ready. I picked up the 9833 for a VERY good price, and it has a multitude of tuning capabilities, so I really cannot complain.
Old Aug 1, 2005 | 04:32 AM
  #114
merovi's Avatar
looks good man!
my eclipse is sirius ready
Old Aug 1, 2005 | 06:12 AM
  #115
cKhuBByBoi's Avatar
lookin very gud man... much props...
Old Aug 1, 2005 | 07:39 AM
  #116
icelandmaxima's Avatar
Maxima Fanatic
Would it be easy for you to replicate the project now that you know how its done?
Old Aug 1, 2005 | 08:01 AM
  #117
Oh, hell yeah...why do you ask?
Old Aug 1, 2005 | 09:19 AM
  #118
cuz he probably wants his done also lol! That's tight.
Old Aug 1, 2005 | 10:00 AM
  #119
Maxima Fanatic
No of course not
Old Aug 1, 2005 | 11:11 AM
  #120
zad1
wow you deff. f@*%ed up your car man
