Radio Staying on when cars OFF?
Old Jun 29, 2005 | 04:44 PM
blkONblk01's Avatar
Ok, My Sub Quit working today?And When I take the key out of the ignition the radio stays on?? Anyone know what could of happened? Is this gonna run my battery down? Also The amp lights are still, I have no clue?
Old Jun 29, 2005 | 05:01 PM
kpr10is's Avatar
This happened all of a sudden?...Is it a factory radio or aftermarket?
Old Jun 29, 2005 | 05:03 PM
blkONblk01's Avatar
It is the factory bose. And Yeah this all happened today
Old Jun 29, 2005 | 05:31 PM
blkONblk01's Avatar
Old Jun 29, 2005 | 07:32 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Where did you get your remote lead from? If ignition, then verify at the amp its not touching constant. If it is, that would be the cause.
kpr10is's Avatar
Which wire is tapped in to for your remote turn on?
Get behind the radio and start testing. The car's accessory wire behind the radio turns the radio on when you put the key in. If you dont have a multimeter to test stuff, start disconnecting one by one til you get it to work. Theres probably nothing anyones going to be able to tell you to magically fix it, just dig in and figure it out.
Old Jun 29, 2005 | 07:41 PM
kpr10is's Avatar
EDIT: Don beat me to it in saying i bet its remote turn on.
Old Jun 29, 2005 | 07:53 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
yea if the constant power is touching the ignition wire even alittle, this will happen.. make sure all your wires to your amp are installed clean in the amp..
Old Jun 29, 2005 | 08:15 PM
rkyat's Avatar
Same thing with me and My Kenwood KVT-911, i have to manually turn it off once the key is out, also i notice if the radio is on, so is my clock, wen i turn the radio off, the clock turns off too. hmm.
Old Jun 30, 2005 | 02:44 AM
blkONblk01's Avatar
I replaced the ground wire with a ground wire with a end connector, the other one was just the wire, so i guess it was touching the other amp wires, and it fixed the problem, but now my other problem is the sub still isnt working.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
MikesChevelle
Aug 9, 2015 11:50 AM
