lights dimming and alternator strain
Old Jul 6, 2005 | 08:05 PM
p00tan6's Avatar
Im running a soundstream 10" spl with a soundstream angina 100Watt rms amp. The lights start to dim when i turn it up loud. What can i do to reduce the strain on the alternator? I'm only running measly 100watt amp, should this even put that much strain on the alternator?
I heard that you can upgrade the ground wire of the alternator to help with the strain. Has anyone done this?
Old Jul 6, 2005 | 09:59 PM
GrazsRootz's Avatar
well upgrading the ground wires n stuff is called upgrading the big3, but with a 100 watt amp you shouldnt have any dimming. check your wiring, do you have a ground wire going from amp to chassis, or amp to battery?
Old Jul 6, 2005 | 11:02 PM
AscendantMax's Avatar
amp to chassis...why would he ground directly to the battery?
Old Jul 6, 2005 | 11:04 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Even with a stock radio, I would suggest upgrading the "big 3" Maximas arent well known for good charging systems.
Old Jul 6, 2005 | 11:14 PM
p00tan6's Avatar
Is upgrading the ground wires on the alternator hard to do? What else is a part of the big 3?? I didn't think i would have problems with only 100 watts either, but the odometer and gauge cluster dims like hell when i turn it up. Also i have an 8 gauge ground wire going from the amp to the chassis.
Old Jul 6, 2005 | 11:18 PM
Pearl96Max's Avatar
Its not hard to do, its simply just upgrading all of your grounding points under the hood.
Old Jul 7, 2005 | 06:26 AM
Batxel's Avatar
blah
I would hold off on the big 3 upgrade for right now. Considering you only have 100w RMS you shouldn't have any dimming at all. Double check your wiring, make sure you are using a good ground and stop over at your local autozone or sears and get your alternator/battery checked out.
Old Jul 7, 2005 | 08:15 AM
guavo's Avatar
How are your battery terminals? I actually had to replace the positive one when I did my amp install... it was corroded almost the entire way through. Replaced it with a more solid piece (my stock one was very thin). BTW, I'm running around 800W RMS with no dimming issues.
Old Jul 7, 2005 | 09:48 AM
jigga123's Avatar
I agree, you shouldnt have any or barely any dimming with that much power. Double check all your connections, wires,fuses, everything. It can also be a sign of a weak battery or alternator that is going out.
Old Jul 7, 2005 | 07:18 PM
raga55's Avatar
what year is your car?
Old Jul 7, 2005 | 08:47 PM
Maximeltman's Avatar
do the big 3 like pearl and others said. and turn the gain down a bit.
Old Jul 8, 2005 | 02:15 PM
Supercross's Avatar
I notice these symptoms on my car also. But for me it only happens when I turn my deck to like 65+ volume, which is really loud, so I'm not really worried about it.
mvm062
Nov 30, 2020 09:00 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
JoshG
Sep 5, 2015 10:10 PM
