What are the best wires?
Old Jul 14, 2005 | 07:51 PM
Shady33e's Avatar
I wanted to know what were the best wires i could get, what brand?
And as for gauge size, i'm running a 3000 watt amp and 2 12" 700 watts RMS each(1400 max each). My friend told me to go for 4 gauge wires...thanks
Old Jul 14, 2005 | 08:02 PM
AscendantMax's Avatar
what make and model amp?
Old Jul 14, 2005 | 08:20 PM
kpr10is's Avatar
Gauge wire depends on the current draw of the amp, not its max power rating. Check the fuses on the side of the amp, add them together, and post up what the total max current draw is. Or a make and model will probably work too.
Old Jul 14, 2005 | 11:57 PM
Shady33e's Avatar
i dont have the AMP yet but thats wut the side looks like
im guessing that says 9 on both...?or maybe 6 hmmm
Old Jul 15, 2005 | 12:10 AM
PandaXpress's Avatar
no dont buy it!......no dont buy it..it is legacy...do not buy it..legacy sux..lol...i can see the word...dont..and best wiring for amp - sub is monstar cable...
Old Jul 15, 2005 | 12:16 AM
Shady33e's Avatar
lmao but i dont hav that much cash i just bought a G35 and i dont feel lik wasting that much cash on the max nemore...wuts better then cuz loook....i hav this already
2 Audiobahns AW1200N Dual 4 OHM Subs 12" 700 watts RMS each 1400 max
and in sounddomain these are my options...
Obviously option 2 is alot more expensive so i want the Mono amp that supplies enough power to my subs wut should i do then
Old Jul 15, 2005 | 12:21 AM
Shady33e's Avatar
oh and another question....when deciding on the amp...how should u know wut amp to get regarding power...because OHMs i already kno....^^^but is it RMS that matters? or max?
Old Jul 15, 2005 | 01:58 AM
505max94se's Avatar
how is option 1 more expensive than option 2??? They're just examples of how to hook up your subs.
Max power isn't real power. It's what audio companies (usually the crappy ones) use to rate there amps/subs. They measure the amount of power the amp can put out right before it blows up under unrealistic circumstances. Max power is pure bs. You should be looking at rms power ratings from a good brand.
Do your self a favor and get rid of that legacy amp.
BTW if you keep it you'll probably need 4 awg
Old Jul 15, 2005 | 07:13 AM
Batxel's Avatar
blah
Getting 1400w RMS out that thing is a far fetched goal. Unless Legacy has changed in the past 5 years, they are one of best when it comes to overrating an amplifier. If you get yourself a true 1400w rms I would recommend 2 gauge wiring and go for the cheapest wiring kit you can buy (knukonceptz are cheap). If your heart is set on that legacy 4 gauge will be fine besides it looks difficult to install with terminals facing that way. It'll be easier to find an amp that put out this type of power at 1 ohm rather than 4 so option 1 might be the better wiring plan to go with.
Old Jul 15, 2005 | 08:03 AM
Shady33e's Avatar
exactly i want option 1, and i know max power is bs...thats why i stated that my audiobahns are at 700 watts RMS each...so wut i need is an amp that pushes 1400w RMS @1 ohm...and stable too right? wuts the best amp
Old Jul 15, 2005 | 08:10 AM
jigga123's Avatar
OK first off, your gonna waste your money on that amp. Secondly, whats your budget for a amp? That Legacy amp is prolly like 400 watts RMS.
Old Jul 15, 2005 | 08:33 AM
Shady33e's Avatar
lmao...i can spend under 250 for the amp...i was lookin at other amps...but i want a good amp that actually supplies 1400w rms (or more) @ 1 OHM, and Stable too
Old Jul 15, 2005 | 08:38 AM
Shady33e's Avatar
i saw a boss amp that says 3000 watts w/e i kno its alot under that but its not 1 ohm stable...
Old Jul 15, 2005 | 09:24 AM
jigga123's Avatar
For $250 that can be done.
http://cgi.ebay.com/Directed-Viper-A...QQcmdZViewItem
Thats your best bet. Will put out around 1500 at 1 ohm. You may also wanna look for a Hifonics 1500d.
Old Jul 15, 2005 | 01:46 PM
Shady33e's Avatar
wow thanks alot bro....plus the Legacy wass a joke the whole time i want an audiobahn or fosgate lol just sumthing i typed in for a 1 ohm stable amp and thats wut i found....thanks alot jigga...ill send u pics of the finished product
Old Jul 15, 2005 | 02:58 PM
jigga123's Avatar
No problem, enjoy. Set your gains correctly and leave the Bass Boost off and you should have a long long investment.
Old Jul 15, 2005 | 07:57 PM
Shady33e's Avatar
yea...i found a Hifoniks amp that ima buy... same **** as the Viper one...so wut would be the best gauge wire to get...my friend told me to get 4 gauge
Old Jul 15, 2005 | 08:09 PM
jigga123's Avatar
I would get the Viper IMO, much better quality. 4 gauge may be enough but I would suggest running 0 gauge to a D-Block and then 4 gauge from there.
Old Jul 15, 2005 | 09:06 PM
Shady33e's Avatar
ok...well at least the hifoniks is better than a legacy...
Old Jul 15, 2005 | 09:47 PM
mendon99's Avatar
tastey wheat
if you're really truly running over a 1000 watts, you need to be running larger than 4 awg wire...
Old Jul 16, 2005 | 07:12 AM
BBOYSTEVIE's Avatar
Back from Hibernation
Was the Audiobahn a joke too?
Old Jul 16, 2005 | 07:19 AM
BBOYSTEVIE's Avatar
Oh, and as far as "best wires"...as long as you get enough current, theres no audible difference. I would also be willing to bet in most car systems (yours and mine included) if not all, you or I wouldn't be able to tell a difference in a blind AB test switching up speaker wire and RCA's, cheap vs. expensive (as long as one of the RCA didn't pick up noise).
So in other words, find cheap flexible 0 guage wire and cheap RCA's that match your install or give you what you want at a nice pricepoint. If you're looking to make your car sound good, spend less on wiring and the money you saved on dampening. www.knukonceptz.com is a popular choice or you can get most/everything you need at parts express. Hell, I think my power wire is "boss"...it gets er done though
Just my .02
Old Jul 18, 2005 | 03:55 AM
Tony Fernandes's Avatar
You still haven't told us how many amps your amp will be drawing. A lot of people will recommend a larger size power wire than you might actually need. Go HERE for some tables that list wire size vs. amps vs. length. You can even input the variables yourself to see the difference they make. On the right-hand side there are multiple links...chapter 16 is on WIRE...that's what you want. Good luck.
Tony
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
