Bose Wire Colors '96
Old Jul 20, 2005 | 04:43 PM
Majestic's Avatar
Yahhhhhhh
Bose Wire Colors/New HU install/Not Noob Question
Hello Orgers. I have a '96 Bose system but my CD player on my HU died. I have been trying to connect the bose speakers to the low level output of my Sony HU but I can't seem to find the CORRECT wire colors anywhere. I've been to installdr, carstereohelp, etc. Nowhere seems to have the correct wire colors. There are two white connectors. One small and on larger. 10 on one and 6 on the other. There aren't many wire with stripes on them. Please help.
EDIT: I did go to carstereohelp and I found a page that has connectors that look like mine. However, they just show the wires by placement and not by color. I used this diagram to connect the power wires and ground wires of the Sony HU. The HU powers on but I get no sound when I connect the wire leads or when I connect the low level output rca's. Am I doing' something wrong?
Old Jul 20, 2005 | 04:47 PM
kpr10is's Avatar
Are you using a wiring harness?
Please refer to the 2nd to last post in the Car Audio FAQ Links Sticky at the top of this forum for all your options for this install.
Old Jul 20, 2005 | 04:53 PM
Majestic's Avatar
Yahhhhhhh
I'm using the stock wire harness. I cut the wires and spliced them. I cut the wires that go to the connector that plugs directly into the HU.
That post is exactly what I used as reference and those wire colors don't match at all.
EDIT: I also have the PAC OEM2 unit. I still will need to know the wire colors.
Old Jul 20, 2005 | 05:19 PM
Majestic's Avatar
Yahhhhhhh
Am I supposed to be using some wires other than these?
Old Jul 20, 2005 | 05:23 PM
kpr10is's Avatar
Well at least you read the sticky. Thats good.
Spend 10-15 bucks and buy a wiring harness that connects to the OEM one, that you can connect to, instead of mangling the stock wiring. 100% easier and your wiring will match up color to color.
Old Jul 20, 2005 | 05:44 PM
Majestic's Avatar
Yahhhhhhh
I guess I should have got the oem1. Do I have any alternatives? The damn wires are already cut now. I just need to know which ones are which.
Old Jul 20, 2005 | 08:32 PM
kpr10is's Avatar
Id still buy the 7550 harness from a local shop if you still have your factory end. This will guarantee you get your colors right, since all aftermarket colors are the same you can just match up the pins of each plug. Then return the harness when done.
Old Jul 21, 2005 | 05:26 AM
Majestic's Avatar
Yahhhhhhh
Sounds like a plan. Still hard to believe that no one on here has any idea. Thanks guys.
Old Jul 21, 2005 | 08:25 AM
Majestic's Avatar
Yahhhhhhh
Bump......Any more ideas?
Old Jul 21, 2005 | 10:41 AM
Majestic's Avatar
Yahhhhhhh
I just found out that there is a wire on the pinout that says "amp on signal". If this is not connected will I not get any sound? Do I need to connect this to a 12volt signal?
Old Jul 23, 2005 | 12:25 PM
Majestic's Avatar
Yahhhhhhh
Ok. It was the amp wire. I forgot to connect it. Sounds okay without the PAC interface. Im going to connect it with the interface and how how much better it sounds. Thanks guys.
Old Aug 26, 2005 | 11:32 AM
ncalsurfer's Avatar
Do you still have your old Bose HU? I might be interested in buying it from you.
Thanks.
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
popdedop
Sep 11, 2015 11:17 AM
