Where did you mount your sub boost knobs?
Old Jul 25, 2005 | 11:10 AM
KCMaxima98's Avatar
Where did you mount your sub boost *****?
I recently bought an amp with a remote bass boost ****. I doubt I will use it much but I figure that I'll go ahead and install it anyway. Im curious where everyone else mounted theirs at. Since I have a GXE, I have a couple of slots under my h/u and I was thinking about drilling a small hole in the back of one of those to run the wire through but Im unsure how I would mount the actual **** in there though. Any suggestions???
Old Jul 25, 2005 | 02:21 PM
sunten1
i did mine on the right side under the dash, and about at knee hieght
Old Jul 25, 2005 | 02:23 PM
AscendantMax's Avatar
mounted mine under the dash, left side of the steering wheel. i predrilled some mounting holes on the dash trim, so it won't crack when i screw on the bracket for the ****.
Old Jul 25, 2005 | 03:29 PM
djfrestyl's Avatar
Suspension Yoda
I disassembled mine and panel mounted it in a spare blank panel below and to the left of the steering wheel. There's two blank panels there.
Old Jul 25, 2005 | 03:42 PM
BBOYSTEVIE's Avatar
Back from Hibernation
In my 4th gen...Inside the ash tray ...Close it up to hide it, pop it open to play
Had to take apart the standard houseing that came with my level controller, eventually leaving a ****, and microchippy thing that had the wires coming from it. At that point it was small enough to fit in there (once the removable ash tray part is gone). I unscrewwed the ****, took it off, used a little piece of plexi cut to the size of the ahs tray holder, a little square...drilled a hole in the center, mounted it with hot glue, covered, put **** back on.....
Old Jul 25, 2005 | 04:45 PM
BBOYSTEVIE's Avatar
http://www.bboystevie1.elitecaraudio.org/photo.html
Old Jul 26, 2005 | 02:52 AM
Tony Fernandes's Avatar
Originally Posted by BBOYSTEVIE
Damn! You need to clean your car!!! LOL
Tony
Old Jul 26, 2005 | 02:58 AM
This is where I've had it mounted for quite a while, but I've been thinking of relocating it to where the heated seat buttons are underneath the e-brake handle. This will be easier and more convenient since my right arm is always resting on the arm rest anyway. I'm thinking of relocating the heated seat buttons up in the dash where I can see them (I keep forgetting to turn the passenger seat off).
Old Jul 26, 2005 | 03:24 AM
BBOYSTEVIE's Avatar
Tony
Yeah, it's clean now...but I never have been the most organized, cleanest installer Costs me a lot of time too....
Old Jul 26, 2005 | 05:44 AM
KCMaxima98's Avatar
Wow, thanks for the good ideas everyone. It looks nice up in those spare panels by the steering wheel. How do those things pop out of there?
Old Jul 26, 2005 | 05:53 AM
djfrestyl's Avatar
Suspension Yoda
Carefully use a very thin screwdriver or knife.
Or you can just unclip them from behind, if your hand is small enough.
Old Jul 26, 2005 | 06:41 AM
KCMaxima98's Avatar
Damn, both of those panels are filled....one for the cruise control switch, and the other has my warn light for my viper alarm. There is a blank panel on the right side next to my dashlight dimmer that might work if I can even get back there. UPS should deliver the amp tomorrow. I'll have to see what it will take to tear apart the switch for the boost and hopefully it will fit in there.
Old Jul 26, 2005 | 06:49 AM
djfrestyl's Avatar
Suspension Yoda
Move the Viper light to the one next to the dimmer. Then you have a blank panel where you want it.
Old Jul 26, 2005 | 08:50 AM
MannyNJ2k2max's Avatar
This is where i used to have it....its no longer in use tho...
Old Jul 26, 2005 | 08:55 AM
tigerxp17's Avatar
I'm working in putting mine inside the ash tray. in the console
Old Jul 26, 2005 | 11:25 AM
KCMaxima98's Avatar
I wish I had those blank panels next to the e-brake. It would make for a much easier install. I can't figure out why I don't have those since I don't have heated seats...maybe 98-99 is different?
Old Jul 26, 2005 | 11:30 AM
djfrestyl's Avatar
Suspension Yoda
I would attribute it to the fact that Manny's car is a 5th gen? The dash is drastically different.
Old Jul 26, 2005 | 01:03 PM
KCMaxima98's Avatar
Oh yeah . Where do they put the heated seat switch in the 4th gens that came with it?
Old Jul 26, 2005 | 01:16 PM
BBOYSTEVIE's Avatar
There are areas of the whole center console assembly that will easily accomidate having a bass control **** through it, not far from the general area that Manny had his mounted in his 5th gen.
Take out the center consile and look under there...there's plenty of room by the cupholders and near why my Automatic shifter is.....
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Unclejunebug
Apr 2, 2016 05:42 AM
atriuum
Sep 28, 2015 01:19 PM
