Avic-n2 VSS(vehicle speed sensor) wire question.
Old Aug 3, 2005 | 07:08 AM
goldmaxNYC's Avatar
i need a little help ...everything is going good with my install of N2.
but have a question where is this damn VSS wire that i need to tap.
anyone know ? anyone has a a diagram? or a pic by any chance or at least a description... i need help please.
Old Aug 3, 2005 | 08:47 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Behind the gauge cluster. Brown center harness, pink/blue wire.
Old Aug 3, 2005 | 08:51 AM
goldmaxNYC's Avatar
once again ...you are the man.
thanks alot.
Old Aug 3, 2005 | 08:56 AM
goldmaxNYC's Avatar
btw.. by any chance do u sell the reverse cameras ?
Old Aug 3, 2005 | 04:39 PM
tomz17's Avatar
Should put this in a FAQ somewhere... :-)
Anyway, i have a picture of the wire you want (http://www.tomz.org/avictut ). You can double check it by throwing the car in neutral and watching the output with a voltmeter or scope. You should get a pulse after you roll a few ft.
Old Aug 3, 2005 | 06:12 PM
goldmaxNYC's Avatar
thanks for the info. just finished everything ....what a Pain in the ....
but all done .....but for some reason now ...my airbag light blinks..... hmmmm
EDIT: after searching the org.. found out that airbag light will come on if the passenger seat side air bag is disconnected while starting the car.
which of course i did to test the operation of the radio before i put everything back in.
and THanks to the org i found the reset procedure on how to reset it .
mrc00l88
Jan 25, 2024 01:14 PM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
