Indiglo Gauge Install: EASY
Reverse Glow/Indiglo Gauge Install: EASY
so i just did this install, and i will get pictures tomorrow, to make an official sticky for it.
2000 maxima
i used these wires;
(1)Parking Lights: red/blue (+) Location: driver kick panel
(2)and if you look under the dash, you will see where the other ground wires are attached, and attach it to that spot.
remove the entire lower panel to get a view of the fuse box there. splice the wire (red/blue) so that there is enough room to work with. i barely had enough room, and actually cut some of the wire from the gauge kit off to use it.
there is where i attached my ground point. the copper colored connector with large black wires coming into it, and my one little black wire coming into it.
as for attaching the remote and the epicenter box, i just ziptied them tightly under the dash, along the steering wheel bracket area. they come on when i turn my parking lights on
completed. remove your negative battery cable if you are afraid of shocking yourself, and i am in no way responsible of you messing this up. and i am not an electronics expert at all.
2000 maxima
i used these wires;
ha, i didnt post a picture there, i just meant to bring it to the top of the audio/electronics thread. you can see them light up when you are looking at them on ebay. it seriously is the the exact same. though if you really want a picture i will go take one, though it is 11am here
Apr 16, 2020 05:15 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
