Avic D1 N2 Lockout Bypass Instructions
Old Aug 10, 2005 | 11:15 AM
tomz17's Avatar
Found this on rec.car.audio and the 12volt forums.. Haven't tried it myself yet. Anyone know if it works?
-Tom
Hope this is OK to make a clean post of this, but alot of people are asking about this and the multi-page threads are not so clear. It contains some updated information from the original rec.audio.car post, as well.
Below are instructions on how to bypass the lockouts on the Pioneer AVIC-N2 and AVIC-D1. It is real simple, and does not require any complex switches or anything. We figure these are service or testing modes, and were not intended to become public. Our Pioneer guy claims to not know anything about it, but who knows, that may just be a line.
This bypass will do three things:
1. Makes all nav functions available while driving (just like they should be)
2. Make video playback available while driving
3. No more parking brake warning box!!!
AVIC-N2 lockout bypass: Underneath the MAIN unit (not the hideaway) is a small silver sticker, peel this back. There are two contacts with the label "R197". Drop a bit of solder between these to connect them. Also, you must ground the Parking Brake wire.
AVIC-D1 lockout bypass: Find an extra Pioneer wire harness, and pull one of the wires out. Or, if you do not use the A.ANT lead, pull that out of the harness. In the AVIC-D1 harness, there is one open spot on the connector (next to the ground wire). Put the wire into the open spot on the connector, connect the other side to ground, then re-connect the plug to the AVIC-D1. Also, you must ground the Parking Brake wire (or connect to a toggle switch if you feel the need).
Thats it, all there is to it, and all the lockouts are bypassed. Easy, give it a try.
Old Aug 10, 2005 | 12:15 PM
Pearl96Max's Avatar
I tend to get a bit irritable
I knew about the N2 one, but it voids all warranties. I didnt wanna put it out there because of that reason.
Old Aug 10, 2005 | 12:37 PM
tomz17's Avatar
heh... well, it's up to the user whether or not they want to violate warranty, esp considering that the only other advice online involved 3 relays and splicing a whole bunch of wires that weren't meant to be spliced. In any case the avic D1 hack seems to be fairly transparent in that if you need to send in the unit for warranty service you can remove the evidence really easily.
-Tom
P.S. now to figure out how to get into the service menus. I know they exist because i see them in the firmware, but i haven't been quite able to figure out how to activate them!
Old Aug 10, 2005 | 01:40 PM
99MAXSE-L's Avatar
Good Find.....thanks
Old Aug 10, 2005 | 01:48 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
grounding the "park wire" works on some units, this will let you play movies while driving... I know that much..
Old Aug 10, 2005 | 06:26 PM
Ladzio's Avatar
Great find. I am considering D1 strongly now since it is 2-DIN (a must, hate flipouts) and has NavTraffic capability. I wish it played back DVDs as well.
Old Aug 10, 2005 | 06:37 PM
tomz17's Avatar
The N1 with old software. The updated N1's, N2's and D1's reference the VSS and gps velocity as well to determine whether or not you are moving.
Old Aug 10, 2005 | 06:39 PM
tomz17's Avatar
$30 or so on e-bay will buy a portable DVD player which you can just hook into the aux-in on this baby. (perhaps put the actual player in the glovebox or under the seat). If this bypass works you should then be able to watch aux whenever (even while driving).
Old Aug 11, 2005 | 04:06 PM
shoman94's Avatar
Nice...I'm ordering a D1 tonite or tomorrow....
--Jason
Old Aug 11, 2005 | 04:21 PM
tomz17's Avatar
--Jason
Cool... try e-bay, i've seen em go for ~$1000 now!
-Tom
P.S. i'm only like 70% satisfied with the teleatlas routing in the pioneers. It's adequate, but there are still many quirks with the routes generated. Frankly, the routis nav software (navtech) I had on my PDA was much more reliable in generating sane routes! I still have very limited experience with my D1, but the proposed routes have disappointed me a few times already.
Other than that, the product has been excellent.
I also cannot vouch for this bypass trick. I've seen posts claiming it works, but haven't tried it myself yet.... won't have time to open up the dash again until after my prelim... ******* hardest exam ever. 3 days long, 12 subjects (4 we haven't taken classes on yet).
Old Aug 11, 2005 | 05:56 PM
CreativeDesignz's Avatar
yes the mod does work we have done it on 2 customers car one with the N2 and one with the D1. works great no more need for crazy switches!!
Old Aug 11, 2005 | 07:45 PM
tomz17's Avatar
Glad to hear it! Makes me feel a lot better about attempting it myself.
-Tom
Old Aug 11, 2005 | 08:30 PM
white m3 guy's Avatar
damn i wish i knew this before, oh well happy with my eclipse
Old Aug 14, 2005 | 02:36 PM
STACK BUNDLES's Avatar
I Just Purchased The Pioneer Avic N2 In Dash Unit For My 6th Gen, I Also Have Aftermarket Subs And A Amp, Which Are Still Working Fine. Although I Notice The Pio Isn't As Loud, As I Expected/should Be. Volume Goes Up To 62, Which Sounds Like It's Really At 52, The Bose Headunit Seemed As Though It Was Louder. At First I Thought It Was Just Me, But I Don't Think So.
Does This Have To Do With The Adapter From Pac Mentioned Above? Somebody Help
Old Aug 14, 2005 | 08:04 PM
Slow Moe's Avatar
I think I am sold on a N2 now.
Good bit of info..
Old Aug 15, 2005 | 02:23 PM
tomz17's Avatar
Good bit of info..
Why? The D1 is SO much nicer in the dash!
-Tom
Old Aug 22, 2005 | 07:52 PM
shoman94's Avatar
-Tom
Got mine from Myradiostore.com for 1095 shipped.....and I get the Pioneer warranty....
Ordered the Pioneer XM/NAV box from ebay for 180 shipped.....I'll have them in my hands on Wednesday!
Old Aug 22, 2005 | 07:59 PM
tomz17's Avatar
Nice... i know you'll enjoy it.
-Tom
Old Sep 13, 2005 | 05:54 AM
maxhead's Avatar
Thanks for the bypass info. Good find. I did it to my D1 this weekend and it worked like a charm. The D1 is soooooo nice.
Old Sep 13, 2005 | 11:17 AM
cutter's Avatar
Do you think the VSS is accurate and do you like it?
Old Sep 13, 2005 | 06:15 PM
tomz17's Avatar
Yeah, so far so good. The unit is dead on, very frequent updates/fluid motion. It's also never lost satellite signal.
However, I haven't tried it without the VSS connected...
-Tom
Old Sep 13, 2005 | 09:11 PM
maxhead's Avatar
-Tom
Mine too. Everything has been dead on so far. The map portion even shows reasonably accurate depictions of buildings so when you're driving through cities, for instance, you see on the screen pretty much what you see on the street (for the most part).
Old Sep 13, 2005 | 09:20 PM
SHouKan's Avatar
I got the N2 and I love it. GPS works great except for today when it wacked out a little bit. Popped the Navi DVD back in and it repositioned itself.
- good info on the bypass - but too bad it voids the warranty
- I put in a switch to bypass the navi system but doesn't work on the dvd playback.
Old Sep 14, 2005 | 04:57 PM
Woody's Avatar
I saw this last week and did it.
The sticker doesn't say anything about void if removed, Dropped in a bit of solder and I'm good to go, everything works as if it did not have a lock out, + you can watch DVD's while driving.
I'm still up in the air about this voiding the warranty. Even the brain, has void if removed stickers, but this does not.
I'm a million times more happy with my avic N2 now.
Old Oct 2, 2005 | 08:41 PM
Progress's Avatar
It's business time.
Bump:
When I had my N1 I could watch videos during driving and I had no warnings or anything about a parking brake. Obviously I never drove and watched DVDs but when it comes to the D1 if I get it installed will I be able to use the navi while driving? Also, what did the shop do when they installed my N1 that allowed me to drive and watch DVDs?
Old Oct 2, 2005 | 08:48 PM
Pearl96Max's Avatar
It WILL void the warranty.
Old Oct 5, 2005 | 11:24 AM
ptatohed's Avatar
Licensed to Spell
I waited for months for the D-1 to come out - only to find out it did not play DVDs. I was bummed because I otherwise would really have loved to get it. I went with the Kenwood 8017.
http://forums.maxima.org/showthread.php?p=4298945
Old Apr 10, 2007 | 01:08 AM
dans04max's Avatar
Does anyone know where the VSS wire is located on an '04 Maxima w/out Bose
05' MaximaMan
Oct 8, 2017 06:36 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
jwright36
Sep 8, 2015 11:45 AM
