firewall question!!
Old Aug 16, 2005 | 08:01 PM
MaxFanatik's Avatar
firewall question!!
this is fora 99 maxima...... i saw a thread started last week and pictures showing where the power wire should go thru the firewall.......left of the master cylinder.... i dont got a hole there unless i drill one
Old Aug 16, 2005 | 08:02 PM
kpr10is's Avatar
Your in Edison. Have Don install it
Or just drill.
Old Aug 16, 2005 | 08:07 PM
makdaddy386's Avatar
Don't be scared to drill if you need to. As long as you seal the hole when your done, there is nothing wrong with this.
Old Aug 16, 2005 | 08:17 PM
MaxFanatik's Avatar
ahh so drilling it is ........ didnt want to but o well lol
Old Aug 25, 2005 | 10:42 AM
ryant35's Avatar
Be sure to insulate the wire with a rubber gromet so it doesn't rub and wear our the wire's insulation and cause a short.
Old Aug 25, 2005 | 02:13 PM
sunten1
What happens when it shorts?
Old Aug 25, 2005 | 04:52 PM
Ohiomike1101's Avatar
It sparks and could damage equipment.
Old Aug 25, 2005 | 06:54 PM
ryant35's Avatar
If your smart enough to install an inline fuse between the battery & the fire wall, it will blow it. If not, if could do all kinds of damage, to what exactly? I'm not sure. It depends on where the wire goes.
Old Aug 25, 2005 | 07:09 PM
sunten1
Alright just making sure, cuz i have a fuse at the battery and on the amp itself
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
