WHOA Slick help a brotha out REALMOFEXURSION
Old Aug 18, 2005 | 05:50 PM
sunten1
There making fun of me....!!!!!!
http://realmofexcursion.com/phpBB2/v...hp?p=3003#3003
I saw more videos of other atlas's and DA MN
You can see the amp setting on the web site
I am running Apline 9827
Amp- Profile 1000m running at 310watt rms
15in Atlas (if you couldn't figure it out)
I bought wire off Crutchfield for 40bucks (power, ground, fuse, rca, lead)
Streetwire speaker wire...
The only thing I can thing of being the problem is RCAs but I highly don't it would make this my of a difference....
Old Aug 18, 2005 | 06:03 PM
slickrick's Avatar
i have 56k so i cant check out the vid until tomorrow night but LNT should not move much at all because of your tuning. send me the video via email at MJSPTK@AOL.COM.
Old Aug 18, 2005 | 06:29 PM
adroga's Avatar
u sure the sub is screwed fully into the box and no air is escaping?
Old Aug 18, 2005 | 06:43 PM
sunten1
Ya...as far as i know
The carpet goes inside the sub back like 2 inches...so i know it sealed off prettty well..
Old Aug 18, 2005 | 06:50 PM
AscendantMax's Avatar
ah yes, i was also wondering why your sub didn't move much to LNT.
at first i thought it was your SSF set too high, but all the settings look ok to me...
Old Aug 18, 2005 | 06:59 PM
yeah, but the bass notes in the song doesn't centralize around one frequency.
Old Aug 18, 2005 | 08:19 PM
slickrick's Avatar
well i havent seen the video to comment on it but lets remember a few things: its a ported box, its a 15, and its getting 300 watts rms being taped on a digi cam i bet. this all equates to...NOTHING when compared to the stuff on that site. its one thing if he is playing tones below tuning at high volume and getting no excursion.
Old Aug 18, 2005 | 08:54 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Why is your phase in the middle?
Old Aug 18, 2005 | 09:03 PM
sunten1
I dunno I read some guide online and it said put it where it sounds the best so I just kinda put it in the middle...
Old Aug 18, 2005 | 09:12 PM
Pearl96Max's Avatar
Never heard that one before. Typically youll either be at 0 or 180 to reverse it. Thats why alot of amps have just a phase switch. Might wanna try moving it.
Old Aug 18, 2005 | 09:28 PM
sunten1
ok ill try it tomorrow Thanx man
Old Aug 19, 2005 | 02:37 PM
sunten1
Well today I moved the Phase so it was 180 and it sounded different...but I am not sure about better...
Old Aug 19, 2005 | 04:33 PM
did you try 0 ?
Old Aug 19, 2005 | 06:52 PM
sunten1
Ok this is what I noticed
When it was at 0 I noticed that it was blended into the music...
But not at 180 you can hear the bass...
So I am guess that it has something to do with the frequency and it shifts it over so it can be heard...lol I have no idea...
Old Aug 19, 2005 | 10:12 PM
mendon99's Avatar
tastey wheat
are you sure you have the wires hooked up from the amp to the sub correctly (is this called 'correct phase'? whatever)
what i mean is + to +,and - to -.. you may have the wires from the sub itself to the box terminals wired backwards, and you may not know it. just a thought, happened to me by accident once, and i wasn't getting much excursion or power...
Old Aug 19, 2005 | 11:35 PM
Pearl96Max's Avatar
Phase has nothing to do with tuning or frequencies. It is simply reversing the polarity of the sub. Same thing as switching your positive with negative lead on the amp, just simplier.
Old Aug 20, 2005 | 06:33 AM
sunten1
Ohh I get it...so Ill go put it on zero today...
Old Aug 20, 2005 | 08:57 AM
sunten1
I was wondering if I should upgrade my rca cables. This is the one that I bought http://www.crutchfield.com/S-5V5ac5K...g=711&I=211AK4
How much of a difference will it make with a set of knukonceptz rca's
Old Aug 20, 2005 | 09:24 AM
i doubt it'll make a difference.
Old Aug 25, 2005 | 08:39 PM
nismos14's Avatar
§è~® f®ÈÄk
Wow so many things wrong on those settings...... Keep the phase to 0 or 180 not 90.Turn that gain down on the amp to 1/2 or so, adjust the bass boost to 1/4 - 1/2 maybe even 3/4 to where it sounds the best, then come back to us
Maxima_Joe
Nov 25, 2015 08:19 AM
Xi MaX SC
1/4 and 1/8 Mile Racing
Aug 7, 2015 08:47 AM
redmaxpa007
Aug 18, 2001 06:05 AM
redmaxpa007
Mar 11, 2001 08:42 AM
