5.5 gen amp install help
Old Sep 29, 2005 | 10:26 PM
maxspeedse02's Avatar
Thinks he is fast
Hey guys I've googled everything that I possibly could about running power wire through the firewall on my 02 max se. I have a 6 speed so I cannot use the slave cylinder hole. I was looking around today under the hood and I have no idea where to go. Any grommets or factory wiring that could be used? I would prefer not to drill but if there is a secure spot then I'm not above it. Any pictures or help are much appreciated.
Old Oct 14, 2005 | 10:26 AM
WxAxGxS's Avatar
Bump... I'm interested too. I know I saw something a while back, but can't find it.
Thanks!
Old Oct 14, 2005 | 12:33 PM
snair2's Avatar
On my 5th gen (2000 Max SE), all I had to do was remove the front driver side wheel, then pull away all the wheel well covers, and you'll see a big grommet. Pull the grommet aside, slip your power wire through it, and it'll go into the interior fine. Hopefuly that's the same way you can do for your car.
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
MikesChevelle
Aug 19, 2015 07:19 AM
MaxStock
Aug 14, 2015 10:03 PM
MaxStock
Aug 12, 2015 08:33 AM
