props to filtor1 and kpr10is!!!!!!!!!!!!! click me for pics
Old Oct 14, 2005 | 02:58 PM
reygarcia's Avatar
Loved by MrGone longtime
this thread is long overdue for me. i came back from iraq last month and chris (filtor1) and kevin (kpr10is) came to my house and installed my viper 791xv with remote start and my subs and amp. they did this while me and wife spent the day in orlando.
so again to chris and kevin
here are some of the pics
seats out
bose out
a broken clip here fixed with epoxy
rear deck with stinger roadkill
Old Oct 14, 2005 | 02:59 PM
reygarcia's Avatar
this was chris' lunch
almost done
clean shot of the amp
red top and power wire
reygarcia's Avatar
kevin under the steering column
steering column all tore up
a shot of the subs
viper remote and key
Old Oct 14, 2005 | 03:04 PM
AscendantMax's Avatar
those two knows their stuff
looks good, wished i was closer to them so i can get my 791 installed as well
Old Oct 14, 2005 | 03:17 PM
BBOYSTEVIE's Avatar
Back from Hibernation
Looks awesome, nice simple and clean. Thats a solid day's work. Thanks for your service in Iraq, by the way....
Old Oct 14, 2005 | 03:32 PM
slickrick's Avatar
seen the pix before good work guys. what did you all do to keep the optima high enough to use the stock bttery tie down?
Old Oct 14, 2005 | 04:19 PM
SC2K1's Avatar
Nice looking install. How do you like that Viper alarm and remote start?
Old Oct 14, 2005 | 04:47 PM
kpr10is's Avatar
Thanks for the props everyone
Old Oct 14, 2005 | 05:00 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Good job Kevin and Chris. BTW is that sub issue resolved? I told Chris what to do.
Old Oct 14, 2005 | 07:14 PM
reygarcia's Avatar
the battery cover is beneath it. the ground cable is connected by a clip near the bottom of the tray. i had to remove the cable from the clip to get it to reach the negative post.
Old Oct 14, 2005 | 07:15 PM
reygarcia's Avatar
thanks and your welcome. i had a lot of fun in iraq.
Old Oct 14, 2005 | 07:16 PM
reygarcia's Avatar
i am liking the alarm and remote start alot. i haven't really been able to test out how far i use it. maybe this weeken.
Old Oct 14, 2005 | 07:18 PM
kcidmil's Avatar
Welcome back man... glad to see you made it out of there. So where did you spend your days of glorious fun.
I spent mine in Kirkuk.
Old Oct 14, 2005 | 07:25 PM
reygarcia's Avatar
the sub issue is resolved now. i ended up looking at the fuse holder and saw that one side came off really easy. so i decided to make it a little tighter. while i had the fuse out i noticed some arc marks on it. but it was weird because the amp never turned itself off. i made sure that both sides of the fuse made good contact with the holder. i took it for a test drive and it didn't cut out on me.
Old Oct 14, 2005 | 07:27 PM
reygarcia's Avatar
i was at 2 locations while i was there. first was al-asad, second was mosul. so i did a little bit of travel. it was fun.
Old Oct 14, 2005 | 07:35 PM
MannyNJ2k2max's Avatar
nice work fellas!
Congrats Rey, nice that you are home safe!
Old Oct 14, 2005 | 07:41 PM
kcidmil's Avatar
I spent 4 months in Kirkuk... then took a nice flight over Bagram Afghanistan. Needless to say, after stepping off the plane, I wanted to go right back home, Iraq as a second choice
I did have fun i Kirkuk, though the Kurds are interesting... some of the time they acted like 3 yr olds.
Old Oct 14, 2005 | 09:25 PM
MrGone's Avatar
good work Reytard
Old Oct 14, 2005 | 09:29 PM
filtor1's Avatar
Your welcome Rey. Glad we could source that issue. Sorry it took so long. I had a great time.
Thanks for the compliments everyone!
BTW, the 791 was all Kevin. I might be able to install a 791 one of these days.
Old Oct 14, 2005 | 11:33 PM
2 Da Max's Avatar
dam you guys had to take the whole cluster off too to install the alarm? or was that to run the led?
Old Oct 15, 2005 | 11:32 AM
filtor1's Avatar
To do it correctly, yes. I don't think he wanted to leave the brain on the front seat.
Old Oct 15, 2005 | 12:12 PM
how long did the alarm install take? (just for something to keep in mind when i have mine installed)
Old Oct 16, 2005 | 02:15 AM
kpr10is's Avatar
Rey's was one of my best 791 installs imo, and it shows, not only when you look under the dash, but in the time it took for the install itself. At work they expect me to do one in 4ish hours depending on the car. But thats soldering every connection. Shops other than CC or BB can have it done faster than that, being that their installers will probably have more experience than me, and that they use crimps/t-taps, whereas BB and CC solder. But I guarantee it wont look as clean as ones like rey's. It would take me 10 minutes to get to the alarm brain myself, let alone a thief who doesnt know every single screw/bolt in the car as well as i do.
Old Oct 16, 2005 | 06:50 AM
reygarcia's Avatar
a very nice install it is.
Old Oct 16, 2005 | 11:44 AM
filtor1's Avatar
Most def a professional 791 install.
Old Oct 16, 2005 | 11:49 AM
Pearl96Max's Avatar
Tach wire is behind the instrument cluster.
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
