It finally arrived!
Old Oct 19, 2005 | 07:51 PM
  #41
nismos14's Avatar
§è~® f®ÈÄk
Sweet, now you just have to stop talkin and start installing :P. I'm sure you will be very pleased with it. How many volts will that Kenwood be sending it?
Old Oct 19, 2005 | 07:57 PM
  #42
kcidmil's Avatar
Originally Posted by AscendantMax
i gotta be gentle, can't just shove a big 'ol wire in there...
that's why you trim down the wire till you can shove it in there
Old Oct 19, 2005 | 09:33 PM
  #43
Pearl96Max's Avatar
I tend to get a bit irritable
Hmmmm....Ghetto
Old Oct 19, 2005 | 09:43 PM
  #44
AscendantMax's Avatar
that defeats the purpose of a heavy gauge wire now doesn't it?
Old Oct 23, 2005 | 07:57 AM
  #45
NisAznMonk's Avatar
Originally Posted by PandaXpress
so have you hooked it up yet ascendant?..lemem know how the sub hits also with all that power....congradulations on the amp. lol..sounds like you had a kid or something.
What kind of dogs are those? I want one...
Old Oct 23, 2005 | 08:06 AM
  #46
no fuses pwn me at the moment...
Old Oct 23, 2005 | 09:48 AM
  #47
PandaXpress's Avatar
they are half germanshepard/rottweiler and we are training them as dogs that guard the house...we had a break in so its about that time we do something about it... ...but they are still nice...they already know attack, stop, jump, beg, sit, food, quiet, (we are teaching them bark as we speak..but that one is tricky) and yeah i know this is WAY
Old Oct 23, 2005 | 02:48 PM
  #48
slickrick's Avatar
he hooked it up and...I'll let him post results.
Old Oct 23, 2005 | 03:47 PM
  #49
yes yes, it's temporarily connected to the main power line right now, and it's not tuned correctly yet. but damn, this arc and sub combo ownz!
Old Oct 23, 2005 | 04:11 PM
  #50
snapped a few pics...
a look through the rear arm rest
shot of the sub and box
another angle
still got to get some fuses so can get the distro block and RF amp in (which is soon to be replaced by another amp )
Old Oct 23, 2005 | 04:40 PM
  #51
nismos14's Avatar
§è~® f®ÈÄk
So what is the voltage going to the amp again?
Old Oct 23, 2005 | 05:03 PM
  #52
2 Da Max's Avatar
dam that amp looks hot in the arm rest
Old Oct 23, 2005 | 05:04 PM
  #53
not enough, 2.0 iirc.
i need to upgrade to a newer HU soon. the kenwood is starting to act goofy at times.
Old Oct 23, 2005 | 06:06 PM
  #54
kcidmil's Avatar
Not using the amp defeats the purpose of having one
Old Oct 23, 2005 | 06:13 PM
  #55
ah but it is being used...
Old Oct 23, 2005 | 07:11 PM
  #56
SEmy2K2go's Avatar
Go BUCKS!!!
Gordon, looks nice man. Nice to see you got the wires all cleaned up.
Old Oct 23, 2005 | 07:36 PM
  #57
thanks Tim, i try not to pull an Avi install...
Old Oct 24, 2005 | 07:02 PM
  #58
nismos14's Avatar
§è~® f®ÈÄk
I bet that 2 volts will be just fine.
Old Oct 24, 2005 | 08:44 PM
  #59
maximal's Avatar
don't most spade connectors defeat the purpose of heavy gauge wire?
Old Oct 24, 2005 | 08:49 PM
  #60
slickrick's Avatar
i doubt it.
Old Oct 24, 2005 | 10:37 PM
  #61
Originally Posted by slickrick
i doubt it.
spade connectors shouldn't pose a problem. they come in assorted sizes for different wire gauges.
Old Oct 25, 2005 | 12:35 AM
  #62
505max94se's Avatar
Spade connectors usually won't restrict current flow, even if the end (spade part) looks alot smaller than your wire. For example, the fusible element, metal part that burns out in large fuses (i.e., 150a), looks ALOT smaller than the wire going to and from the fuse. It doesn't matter that it's small in diameter because the fusible element is VERY short. The shorter a wire is, the less resistance it has. So you can use small, short wire to supply the same amount of current as large, long wire (depending on awg and length). Basically, if you have two wires of the same awg, one is 1ft long and the other one is 10ft long, the shorter wire will be able to supply more current.
Old Oct 25, 2005 | 01:07 AM
  #63
HitManSE's Avatar
Looks good
Old Oct 25, 2005 | 02:26 AM
  #64
505max94se's Avatar
BTW, I forgot to compliment on your new arc amp.
Looks really nice. Bet that's plenty of power for the 15.
MaxiNoob98
Oct 2, 2015 10:13 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
