What gauge wire?
Old Oct 23, 2005 | 08:44 PM
Sgibb's Avatar
What gauge wire?
Im getting a 350 watt alpine amp, i was wondering what gauge wire i should go with, i might bridge it later down the road so it will be 700 watts. i was thinking a 2 gauge any opinions?
Old Oct 23, 2005 | 09:07 PM
AscendantMax's Avatar
4 gauge will be good for your purpose.
Old Oct 23, 2005 | 09:11 PM
Sgibb's Avatar
if i get a 2 gauge its not gonan have a negative effect will it?
Old Oct 23, 2005 | 09:15 PM
nope not at all. with a thicker wire, you'll be able to upgrade to a larger system in the future if you decide to.
clean 3rd gen
Old Oct 24, 2005 | 07:07 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Hrrmmmm...this guy lives in the same town as me...
Old Oct 24, 2005 | 07:15 AM
maxgtr2000's Avatar
KH3 by popular demand
I would go with 2 ga. and break it down by distribution block. It wouldn't hurt, you'll always have that power on tap. And when you go slightly deaf and need more base you won't have a restriction of current flow if you decide to go with more/bigger amps.
Old Oct 24, 2005 | 12:25 PM
ElVito1981's Avatar
i'd go with 8 gauge. anything thicker is just way too difficult to work with.
Old Oct 24, 2005 | 12:47 PM
filtor1's Avatar
Umm, are you kidding? My 0gauge is almost exactly as pliable as the JL 4gauge I use from the distribution block to the amps. 8gauge will not be near enough for 700+watts.
I say 4 or 2gauge. 2 if you plan on upgrading in the future.
Old Oct 24, 2005 | 12:50 PM
Please...
Old Oct 24, 2005 | 12:56 PM
filtor1's Avatar
Hahahahaha. You make me laugh.
Old Oct 24, 2005 | 05:10 PM
if i can run a thick wire in my 3rd gen, so can he in his
Old Oct 24, 2005 | 05:25 PM
Another thing I just thought of is that someone just admitted to having teh small p3n0r...
Old Oct 24, 2005 | 07:07 PM
ElVito1981's Avatar
well i'm running 100 watts RMS for each speaker, and only 150 RMS for my sub, so 8 gauge is perfect. Also, i tried 4 gauge and it was too thick to fit in the terminals of the amps.
Old Oct 24, 2005 | 07:53 PM
4 gauge => distro block => 8 gauge to amps.
Old Oct 24, 2005 | 08:01 PM
ElVito1981's Avatar
i'd rather have a straight connection from the battery to the amp, without any interruption.
Old Oct 24, 2005 | 08:10 PM
filtor1's Avatar
Why is this? I hope you at a minimum have an inline fuse.
A wire will loose a specific amount of voltage across 1ft of said wire of a given diameter. If you run 18ft of 8gauge. The drop will be higher than if you choose 17ft of 4gauge and 1ft of 8gauge. This has been my understanding of voltage drop through a distance of wire. Someone correct me if I am wrong here.
Old Oct 24, 2005 | 08:22 PM
well these interruptions will be very minor. i doubt you'll notice at all. how else will these people with multiple amps wire their car?
Miket2006
Mar 1, 2021 03:55 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
