subs in a 5.5 gen..help!
Old Nov 28, 2005 | 04:57 PM
Y2k2maxse's Avatar
hey any help greatly appreciated...how do i get the power wire from the engine bay into the pass compartment? I do not wanna put it around the fender the ghetto way. did anybody drill a hole in the firewall? if so, where exacty? any other ideas?
Old Nov 28, 2005 | 06:42 PM
filtor1's Avatar
Uni-bit through the fire wall. Easiest to go from under the dash.
Old Dec 1, 2005 | 03:45 PM
Y2k2maxse's Avatar
where exactly under the dash it best?
Old Dec 1, 2005 | 04:10 PM
nismo0604's Avatar
cut a hole behind the brake pedal
Old Dec 1, 2005 | 04:53 PM
Nickel's Avatar
you dont have to drill no whole. theres all ready a small whole that is easy to get to
Old Dec 1, 2005 | 04:55 PM
Nickel's Avatar
follow the red wire. then look in your max n youll see a lil plug. take the plug out and youll see the whole.
the wire will end up under the steering wheel to the right a lil bit
after that just hid it under the rug and trew the back seats
Old Dec 1, 2005 | 08:45 PM
filtor1's Avatar
My wire would never fit in such a tiny hole. I pefer to just drill a new one.
Old Dec 1, 2005 | 08:46 PM
filtor1's Avatar
And that isn't there on the 5th gen.
Old Dec 2, 2005 | 06:09 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
The easiest way to route a power wire in the 5th gen is through the diver-side front wheel well.
(1) Remove wheel
(2) Remove pop-tabs for wheel well.
(3) Run the wire from the battery through the OEM hole in the fender for the OEM wiring harness.
(4) You will see that the OEM wiring harness runs through the firewall and down by the dead pedal.
(5) Run your wire through here.
No drilling required.
Old Dec 2, 2005 | 09:21 AM
bookechu's Avatar
Since this is sort of on topic i'll post it here....The forum wont let me post a new thread and was wondering if a 2 15' slot ported box with dimensions 40x 17dx16h, would fit in a 5 or 5.5 maxima. Someone please help me out and take some measurements, I need a new car, and will get a max if it can fit this box...thanks
Old Dec 2, 2005 | 10:19 AM
slickrick's Avatar
or you could pick a car, then see if it fits, then build another box if it doesnt. i have a 40x18x12 box in my 5.5 gen and its a tight squeeze.
Old Dec 2, 2005 | 11:19 AM
bookechu's Avatar
is it a tight fit because it is 18h or because 12 deep
Old Dec 2, 2005 | 11:25 AM
slickrick's Avatar
well you could go about another .5" I'd guess. but i have to turn my box to fit it in because the opening is only so deep. so id say depth is the issue at hand.
Old Dec 2, 2005 | 11:52 AM
TheBigDu's Avatar
Seriously, I'm not blaming the poster, but this question comes up all the time!
This time somebody PLEASE make this a sticky.
In a 5.5 gen, you do what Metal Maxima suggested. Or a slight variation: you run the wire through the hood release cable hole, which is right near the main harness. Pictures:
Old Dec 2, 2005 | 12:48 PM
filtor1's Avatar
Just for clarification, will 0ga fit through the (into cabin) gromet?
I agree about the sticky. Or in the general sticky with all of the basic wireing/routing and stock Bose ?'s answered.
Old Dec 2, 2005 | 01:01 PM
TheBigDu's Avatar
Actually, I don't think anything bigger than 4 awg will fit through the hood release cable passage (I was looking for the wire size but I don't think he listed what he's using). But you'd use the same procedure for the route Metal suggested, which is through the main harness passage, and I'm almost certain 1/0 would fit through there.
Old Dec 2, 2005 | 01:07 PM
filtor1's Avatar
Cool. I use the other method b/c I don't want to take customers wheels off. But for self installation, I like this method you both suggested.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Apr 16, 2020 05:15 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Redfox
Sep 28, 2015 10:41 AM
