Need Help Installing New Sony Xplod on 1990 Maxima PLEASE!!!
Old Jun 4, 2001 | 03:34 AM
BeatJunky's Avatar
I have to install a new Sony Xplod CDXL550X CD Player Stereo Head Unit into my 1990 Nissan Maxima with the Bose Set-Up
The Bose HU had been removed before and replaced with a Pyramid HU. I ripped out the Pyramid HU and am left with bare wires coming straight from the car. I was told by the store where I bought the Sony that I needed an adapter thing in order to install the Sony...
Does anyone know about what they were talking about and how I can install this HU???
Please help!!!
-BeatJunky!
Old Jun 4, 2001 | 04:07 AM
monqy
wiring info if you do not want to buy a harness...
http://www.installdr.com/InstallDoct...san-Wiring.pdf
if you don't feel like cuttin wires, i think crutchfield and autotoys.com sells them. you can try ebay also. as for the actual manufacturers, the only one that i can think of off the top of my head would be scoshe.
hope this helps
/edit
the site changed the url...its updated now
/edit
Old Jun 4, 2001 | 10:05 AM
BeatJunky's Avatar
It helps...
but maybe someone can post some more info...
Old Jun 5, 2001 | 10:11 PM
Matt93SE's Avatar
STFU n00b!
what else do you need? that gives you all the info required to do the job.
Old Jun 6, 2001 | 07:39 AM
BeatJunky's Avatar
Just if any one has any tips or suggestions. This would be my first time doing a HU Install, seems like I picked an "easy" *cough*bulls**t*cough* car to begin with...
But any help that I can get is appreciated.
For Example:
Ground - Does it belong connected to another wire or attached to the harness?
Old Jun 6, 2001 | 12:32 PM
monqy
http://www.installdr.com/InstallDoct...PDF/647021.pdf
thats from the same site as my last link...it provides more detailed information...i dunno if its what you are looking for though. the link i gave you last time has enough info in it for you to hook up your new receiver.
/edit
ah crap...i just realised you have teh bose system...just ignore this then.
/edit
Old Jun 6, 2001 | 01:26 PM
BeatJunky's Avatar
ROFLMAO!
Thanks though...
Old Jun 7, 2001 | 09:24 AM
BeatJunky's Avatar
INSTALLED IT...
Ok, so I have it working (w/o premium wire harness)...
2 Things Though...
1- I had to connect the Remote-Turn On wire to the Power Wire directly... For some reason, When I connected the REM to its other corresponding wire on the car, The unit would not power up when I would turn the car on. Now, It's always powered unless I remove the face from the Stereo.
Am I risking anything by having it this way (EG - Draining Battery)?
How can I resolve this problem?
2- W/o the Premium Wire Harness, my volume and sound are fairly crappy. Supposedly the WH has a volume control which will let me to adjust the sound of the speakers...
Is there any other way around this?
THANK YOU!
Old Jun 9, 2001 | 04:14 PM
CanuckAMP's Avatar
Re: INSTALLED IT...
2 Things Though...
THANK YOU!
Did you mix up initially connecting the remote wire to the power antenna wire? or the wire that turns on the Bose amps?
You could connect the remote start wire to the ignition ACC wire. That would make the deck turn off when the ignition key is not in the "ON" position...
The wire harness for the Bose system actually has level attenuation built in so that the Bose amps don't receive input power higher than their capability to handle safely. I highly recommend you get it.
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
