Alright, set me straight!!
Old Jun 5, 2001 | 02:34 PM
JeepRage's Avatar
ok, in 4th Gen forum, someone said that they bought a JVC KD-SH99 head unit, and that it plugged right into the Bose Din connector... go to crutchfield and check it out, it plays MP3's too... it looks decent, but i want to know what you think. im skeptical of it being compatible with the bose speakers. my HU is in need of repair which is $150 online, or replacing JUST the HU with a different one, but this means stock bose speakers gotta be compatible. i already have 2 10" subs, so im ok in that aspect. i know this is a repetitive Q, but straight up, can ANYTHING be put in place of the bose unit with NO problems with the stock speakers?? anything would help... PLEASE post a response!! Hall
Old Jun 5, 2001 | 04:48 PM
Micah95GLE's Avatar
Any HU will work as long as you install it with the proper adaptor.
Old Jun 5, 2001 | 06:25 PM
jashick's Avatar
If the impedance of the Bose speakers is 1 Ohm, as posted in several areas of this board, then it gets a bit more complicated than that. Most HU's are spec'd to drive 2 or 4 Ohm loads. If one of those is used to drive 1 Ohm speakers, then you run the risk of burning the HU since the load is too great. So at one particular volume setting, the HU will be over-working to drive the 1 Ohm speaker compared to driving a 2 ohm or 4 ohm speaker.
I haven't personally verified the impedance of the Bose speakers.. but if it is in fact rated at 1 Ohm, you run the risk of frying your HU. If you're willing to take that risk, then you can find the appropriate adapter, install an HU, and you will get sound... but you may definitely want to keep the volume down.
Old Jun 6, 2001 | 07:38 AM
JeepRage's Avatar
alright, thanks... so basically you cant replace it with ANYTHING else at all... i mean every stereo can run an adapter, so nothing else is compatible with the stock speakers. i guess its time to send bose in for a repair then. Thanks for the know how... Hall
Old Jun 6, 2001 | 04:55 PM
Micah95GLE's Avatar
This is incorrect. The HU doesn't care what the impedence of the speakers is because the HU doesn't drive the speakers in the Bose system. As I stated before, any HU will work with the correct adaptor. I've seen it done many times.
Old Jun 6, 2001 | 05:12 PM
jashick's Avatar
Damn, you're right... why was I thinking it went straight through?
Old Jun 6, 2001 | 05:47 PM
JeepRage's Avatar
ok, not to kill the subject... but if i do replace the bose HU with a different CD player, W/ an adapter.... i can not/ will not hurt/ruin the stock bose speakers?? i just want to do this once... i want to either repair the bose HU, or replace ONLY the HU with an aftermarket one. thanks for any clarification. Hall
Old Jun 6, 2001 | 07:09 PM
speednsound007's Avatar
new speakers...
are only $100/pair for good speakers, if they do burnout just get new ones...The bose sounds crappy as it is. Also, you should have no problem installing speakers yourself, it's very easy.
PJ
Old Jun 6, 2001 | 09:51 PM
JeepRage's Avatar
Re: new speakers...
PJ
yeah, i know its easy to install, ive done many stereo installs, thing is i dont have the $ for new speakers all around, i just bought the car, and want something decent for now. thats the reason i asked about adding the CD player with stock speakers. now how are the tweeters set up on a 95 ?? will i have to replace them too?? or are those off the fronts?? alright.. let me know
Old Jun 7, 2001 | 04:27 AM
Micah95GLE's Avatar
You don't have to do anything to the speakers. Get just the HU and the adaptor.
Old Jun 7, 2001 | 05:49 AM
PrinzII's Avatar
OG and counting...
Truth be told......
Since each Bose speaker has its own amplifier, the head unit does not have to drive the speakers. Therefore, what Micah said is correct. Get the HU, get the adaptor, connect it and enjoy!
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
