Im stumped
Old Jan 11, 2006 | 08:04 AM
Acerbis's Avatar
Im stumped
For about a years time my system was working fine. A couple days my sub just stopped working completly. I checked the fuses in the amp, theyre all good, the amp lights up and all whatnot so I know that its getting power. Everything else works fine except I cannot get sound to come outta the woofer. Do you guys have any suggestions of where I should look?
Old Jan 11, 2006 | 08:13 AM
MacAlert's Avatar
Check the tinsel (i think thats what its called, its the wires that lead from the terminals) leads. I had the same problem with my Rainbow sub, soldered it back on and it works.
Old Jan 11, 2006 | 08:16 AM
Acerbis's Avatar
Just checked those, they all seem fine to me.
Old Jan 11, 2006 | 08:21 AM
AscendantMax's Avatar
so it just suddenly stopped? can you (carefully) push the sub in and out without much force?
Old Jan 11, 2006 | 08:23 AM
Acerbis's Avatar
Yes I can. What does this test?
Old Jan 11, 2006 | 08:26 AM
it tests whether or not your voice coil(s) are seized. there's NO movement at all when you have music playing?
Old Jan 11, 2006 | 08:37 AM
Acerbis's Avatar
No, there is no movement. Theres no sound at all coming from the sub.
Old Jan 11, 2006 | 08:38 AM
djfrestyl's Avatar
Suspension Yoda
test with another sub. if you don't have one, test with another speaker. keep the gains low.
if you have a meter, test to see whats comin out of your speaker terminals on the amp.
Old Jan 11, 2006 | 08:55 AM
Acerbis's Avatar
Ok i tested it with another speaker and I got sound to come out, so I know its not the amp thats fuggered. Is there anything partiular that I should be aware of on the sub itself?
Old Jan 11, 2006 | 10:32 AM
djfrestyl's Avatar
Suspension Yoda
Besides what Ravi (MacAlert) said, I'm all out of ideas. There should be a way to meter your sub in ohms to see what resistance it has, and if the number is an anomaly then that indicates a problem, however I am not sure about the specific logistics of that test.
Old Jan 11, 2006 | 10:46 AM
nismos14's Avatar
§è~® f®ÈÄk
Sounds like the VC is blown. If you have the sub hooked up and you push in on it a little bit does it start to play?
cruce91
Sep 20, 2015 10:23 AM
lux97Max
19
Aug 27, 2015 07:48 PM
RealityCheck
Aug 5, 2015 06:18 AM
khott2003
Dec 16, 2002 07:29 PM
