Power Inverter
Power Inverter
I installed the Microvision screen with the ciggy lighter. Now I need to wire up the PS2. I'm thinking of mounting it right under the front passenger seat. Where should I get the 12 Volts for the power inverter? Can I wire the power inverter to the ciggy lighter even though I already have the screen there? I only want power going to the PS2 when the key is in the ignition. Like when the radio is on.
Thanks, Aaron
Thanks, Aaron
The cig lighter is rated for up to 15amps I think (check the rating on the cig lighter fuse to be sure). I would expect that the lcd probably only draws about 1 amp. So, you should be OK as long as your inverter is drawing less than 14 amps under the load of your ps2.
for a 1996 it's either red or red/yellow.
its in the ignition harness under the dash. It's a tightly wounded bundle of thick wires (about 10awg). You will have to cut the loom with a razor to get into that wire.
Originally Posted by Black Maxima
Okay, I actually hooked everything up to the cig lighter. Everything works perfectly. I just need to mount the PS2.
If everyone here is right, which I am almost sure is true. If you don't wire it to another accessory or straight to the bat, your going to have some problems like blown fuse or wire melting. Why not run it to the bat and put a switch on it?
Because the last thing I want to do is say "I told you so"
I plug my PS2 into the power inverter on the lower passenger side console area, down near the feet, screwed thru the carpet. With the new PS2, you can fit it in the glove compartment. But I don't leave mine in there, cold weather is no good for PS2's.
How is it wired? Unsure, I had a shop install everything in my car.
If everything works and you're not blowing fuses, then obviously your load on the circuit is within acceptible limits...as long as you haven't done something stupid like put in a higher rated fuse than what is called for.
The lighter can handle the load of a PS2 as well as a few low load items, neons, leds....etc. I've had my inverter (single outlet) wired to the lighter for almost 3 years now and have no problems. Just don't exceed the amp rating and you'll be fine. So don't go throwing a microwave in your car or a 32" TV.
Thank you guys! I was actually thinking a 56" rear projection instead of a 32", but I guess that idea won't work. HAHA What I can do is put a small fuse inside the power inverter so that fuse will break first and not my cig lighter.
There is a fuse on the ciggy lighter too.....No need to put another one (how, I'm not sure) INSIDE the power inverter....
