Aftermarket car audio install
Old Jan 24, 2006 | 02:48 PM
maxchef's Avatar
I have just gutted my max and installed aftermarket audio and video equipment. Its starting to all come together but i have found that when you take the stock cd player and tape deck out you loose your system functions. Let me explain better, I cannot access any of my settings, not the gas milage not any of the settings that used to be able to. All that is displayed on the display and works is the climate control. This is a non nav 2005 se. Any help would be greatly appreciated. Thanks All!!!
Old Jan 24, 2006 | 02:54 PM
kdejour's Avatar
http://www.cardomain.com/my/ed
This is a shot in the dark but maybe you need to take it back and see if they disconnected the wrong wires. I see alot of guys on here with there aftermarket stereos. I haven't heard them say anything about the problem you have. I'm quite sure on of the guys will chime in here and give you some advice for what they did. Try doing a search I did read about the pac system that helps with some of the factory controls. I hope you get it solved though.
Old Jan 24, 2006 | 02:58 PM
maxchef's Avatar
Thanks kdejour, i installed it myself to make sure thisngs were going to be right.....YEAH RIGHT! But everything to the best of my knowledge is all hooked back up correctly......or so i say.LOL!!
Old Jan 24, 2006 | 03:04 PM
KCMAXX's Avatar
KC's FINEST
You have PM
Old Jan 24, 2006 | 03:10 PM
maxchef's Avatar
Thanks KCMAX....I checked it.....its plugged in. I checked my pm too.....will chat with you more about that soon.
Old Jan 24, 2006 | 03:13 PM
KCMAXX's Avatar
KC's FINEST
Did you go aftermarket H/U and video screen? Stock screen lowered?
Old Jan 24, 2006 | 03:16 PM
maxchef's Avatar
LOLOL.......somthing like that. I istalled a double din unit and tried to move the screen but since i had to operate on the stock pannel i had to move the screen back up. Its really weird, i wasnt sure if the stock unit had somthing to do with it.
Old Jan 24, 2006 | 03:59 PM
jsmithsole's Avatar
*moderator*
That is weird, it should be plug and play, minus the stereo functions. I've never had any problems...
Is it possible that you some how cut or damaged the plug somehow while doing your install? Could have broken the wire somewhere??
Sorry can't be more help!
Old Jan 24, 2006 | 04:18 PM
KCMAXX's Avatar
KC's FINEST
Lets tear into it this weekend
Old Jan 24, 2006 | 05:58 PM
Deckdout2's Avatar
Play with my balls
This wouldn't have anything to do with the PAC-SWI adapter would it? I'm not sure if this applies to the 6th gen or in this case even. On 5.5 gens, our trip controls on the steering wheel needs this adapter to make it work again.
Old Jan 24, 2006 | 06:52 PM
maxchef's Avatar
Its all good jsmithsole. I am going to double check things in the morning and see if i can tfind the problem
Old Jan 24, 2006 | 07:04 PM
jsmithsole's Avatar
*moderator*
Nope, they're all on the dash...
maxchef, good luck!!
Old Jan 24, 2006 | 07:07 PM
maxchef's Avatar
Word!!!!!!!!
Old Jan 25, 2006 | 07:31 AM
maxchef's Avatar
I found the issue.........Duh?........the connector didnt click all the way in to the back of the control pannel.......stupid stupid stupid!!!!!!!!.LOL.Thanks anyways for all your feed back. Now.if there is anyone out there that needs some help with installing car audio in a 6gen max.well i am your guy. Let me know if anyone has any questions. Thanks again guys!
Chef
Old Jan 25, 2006 | 08:18 AM
myer84's Avatar
Lol I was jst about to tell u the chck if ur harness clicked. I had da same issue whn I installed my HU. Two of my harnesses didnt click all the way and lost the same functions as u and my steering wheel and mirror adjustmnt functions. Untill I opened up everythng I pushed all of the harnesses in and two of them clicked. Well good thng u fixed it.
Old Jan 25, 2006 | 08:27 AM
jsmithsole's Avatar
*moderator*
lol, good thing is wasn't a deeper problem than that!!
Old Jan 25, 2006 | 08:39 AM
maxchef's Avatar
Yeah no shiznet.....I just HAD to do it myself!.......LOL!!
Old Jan 25, 2006 | 08:53 AM
SmokedOutMaxi's Avatar
nice set up.. not sure about your problem. I was wondering though what are those blue gauges at the bottom?????
Old Jan 25, 2006 | 09:01 AM
maxchef's Avatar
The one on the left is a current draw gauge for my amps. The other is a battery meter for the three extra batteries it will take to power everything once its complete. I searched all over for a pair of gages with blue display, auto meter and dakota digital had them but were way too expensive. So i did a search on the net and came accross "e gauges" great site and cheap too! Did a little glass work to mount them and poof! Thanks for the compliment. Keep cruisin!
Chef
Old Jan 25, 2006 | 09:51 AM
jsmithsole's Avatar
*moderator*
Yeah, those look sweet!
Old Jan 25, 2006 | 10:00 AM
Favs's Avatar
I have a 04 Max and I installed a Pioneer pop out LCD and I can't get the Pac-SWI to work I followed all the instructions I think, unless any one has it done and would be able to take a snap of it so i can make sure i connected right, but for some reason the stereo does not go up in volume or any of the functions its supposed to do. Can any one help?
Old Jan 25, 2006 | 10:33 AM
maxchef's Avatar
Favs..i have not worked with the Pac-SWI. I have totally gutted and replaced every speaker and audio visual piece in the car and ran all new cables and wire. I know that the are some impedance problems when it comes to using the stock bose speakers with an aftermarket H/U. Are you sure the Screen isnt defective? I will check it out on the net and see if i cant get you an answer.
Old Jan 25, 2006 | 11:00 PM
Favs's Avatar
The screen is fine everything else works just fine, the one problem is making the steering wheel work with the aftermarket stereo, Its a non bose stereo so it should be some what easier. But The Pac-SWI seems like it recognizes when i program the commands but after that the stereo seems not to recognise the command from the pac. So i don;t know what to do now. I may beleive to just leave it at that and just forget about the steering wheel controls and not use them. That may be the best bet.
Old Jan 26, 2006 | 01:55 AM
tototee999's Avatar
maxchef,
just wondering, while gutting out your max is it possible to install a double din navigation/dvd unit where the orignial non nav screen is?
hope tha made sense..
thanks,
neir
Old Jan 26, 2006 | 04:27 AM
maxchef's Avatar
There is no way!!!!!!!.there is about 4 inches of depth, then you run into a 3 an a half inch tube........that would be the front body support. No way around it other than to install the double din like i did, take out all the stock stuff and very carfully cut the double din hole in the front face. The double din nav does fit perfect after you take out the stock equipment. Hope this helps and please feel free to ask if you need any other questions answered.
Keep crusin,
Chef
Old Jan 26, 2006 | 04:47 AM
maxchef's Avatar
Favs, I gotcha now!!!!!.i am blonde so it takes me a few to get it. To be honest, i dont know!!!....SORRY man. I did hear that if you wear dark clothes that it wouldnt work because dark clothes absorb the IR transfer, i know it sounds weird but its true. Just a thought for ya.
Old Jan 26, 2006 | 05:37 AM
leolee06's Avatar
hey guys im brand new to the forum and recently bought a 6th gen maxima..im trying to get a radio for it..also change the grill on the car and add some rims any suggestion?
Old Jan 26, 2006 | 05:51 AM
maxchef's Avatar
WELCOME!!!.....just look around this site.......there are some great options to look at. Only advise is to buy what YOU like, not what everyone else likes. Again Welcome, i am sure you will find this site to be informative and helpfull, I DO!
Keep Crusin,
Chef
Old Jan 26, 2006 | 05:55 AM
leolee06's Avatar
thanks for the Welcome.and yea ill be browsing through the forums and learn a thing or 2..once again thank u
Old Jan 26, 2006 | 05:57 AM
leolee06's Avatar
thanks for the welcome ill be browsing through the forum im sure i will learn alot from u guys..once again thanks.
Old Jan 26, 2006 | 07:35 AM
odinala's Avatar
Anyone know what type of CDs will display Track Title or Disc Title on the non-Bose system? This is an option on the audio display, haven't found any of my CDs that will display this info.
Old Jan 26, 2006 | 08:17 AM
myer84's Avatar
Originally Posted by tototee999
maxchef,
thanks,
neir
I'm wondering if the new Clarion Navi systm would fit?
Old Jan 26, 2006 | 10:14 AM
maxchef's Avatar
Meyer84....I dont think anything will go up there except a raw screen, i went through all the different audio manufatures to check dimensions and non of them were even close. But you are right clarion was less deep than everyone else. i even considered taking apart a NVIC1 and mounting just the screen in there but was not cost effective, thus i went with a double din and i am doing all fabrication myself.
Old Jan 26, 2006 | 12:30 PM
Majestic_MAx05's Avatar
Hey I have the Non-Bose system on my 05
When i put in a CDR that has the track titles on them they come up on the screen. There is also a setting that has to be changed if you want the TRACK, TRACK TITLE, or CD TITLE to be displayed
Old Jan 26, 2006 | 01:40 PM
odinala's Avatar
I haven't tried any CDRs, only originals. Maybe it's time to buy a new CD???
Old Jan 26, 2006 | 02:07 PM
KCMAXX's Avatar
KC's FINEST
Burn some with Nero, everything will show...
Old Jan 27, 2006 | 07:35 AM
odinala's Avatar
Hate to sound stupid, but how will Nero add things that aren't on the original CD? I believe the non-Bose system will not play MP3's????
Old Jan 27, 2006 | 07:48 AM
kidd4l's Avatar
Cool Member
I have some original CD's, not all, that show the title and track, so it depends on the CD. Not just non-Bose system, our stock system does not play MP3.
Old Jan 27, 2006 | 08:48 AM
odinala's Avatar
That what I thought, thanks.
Old Jan 27, 2006 | 11:17 PM
Favs's Avatar
Maxcheff thanx for trying thought , apriaciated! I may just leave it with out the steering wheel controls, i am somewhat getting used to it anyways. Thanx though!!
