AVIC-D1 pics ... re-do or not to re-do??
Check it out .. Great HU but looking for another method as far as appearance with another kit. this one was obviously customized - crappy job! recommendations? Yes yes i know the flat CF kit looks like crap too ..i wanna change it to a molded kit eventually....help!
Originally Posted by Metal Maxima
I'm going to be fabricating a peice for TXT-1's D1 this weekend...I'll post pics once it's all done.
anyone else? thoughts or ideas? those who do have a D1... where is your GPS antenna placed?
Originally Posted by TXT-1
Trunk lid for both the XM antenna and the Navi.
I'm not at all familiar with the installation of the D1, but why is the din kit appear to be hacked up? Was it necessary for the install, or was this not a kit, and you made the mounting thing yourself. Just wondering because of the unusual slanted gap under the D1. A friend of mine and I are planning on a similar install, so I'm just curious as to what to expect. Otherwise, that thing looks sick, nice work!
You could use the GXE kit offered at courtesyparts, no? Or is it just too expensive?
http://www.courtesyparts.com/Merchan...de=68750-VENTC
I just bought my D1 did you get the bottom din to play dvd movies if you did tell me how you did it
Nope got with without DVD for now ... TXT-1: you never sent the pics. please try again.
I like the GXE kit way better .. these are TXT-1's pics by the way:
Thanks Ted. Id rather figure out a way of filling that bottom gap then getting prescise measurements to re-do my kit and still have the "picture frame" look...
HOW TO: fill out bottom gap below a D1..ill tell you how...
you can get a piece of plastic that will fit in that spot and mount it in there and from behind do something like hotglue...then put a..Security light?
just a suggestion.
just a suggestion.
just a suggestion.
just a suggestion.
The vent just pops in, you just have to make sure you push it in hard enough.
It's just the vent. You are making it sound harder than it is. Your installer hopefully used the brackets from the stock HU. Once the HU was screwed in, than you just pop the vent on top of that and it will click right in like it was stock. If your installer did not use the stock brackets but instead instead used custom brackets, I am not sure how that would turn out. I would get the stock brackets on there.
If you have further questions, I would PM MetalMaxima as he was the guy that installed my stuff.
i dont think the installer did use the stock brackets if the unit is sticking out like it does. since he also had to add on that black plastic frame. otherwise the brackets would have held the unit flush with the deck right? how can i get my hands on stock brackets?
Do you have any more pics?
04-16-2020 05:15 AM
bigfrank
10-01-2015 12:51 PM
