Aftermarket Radio Install
Old Feb 11, 2006 | 11:33 AM
maxcosity's Avatar
I need some help guys.. I'm putting in an aftermarket head unit.
It has a fold-down, removable faceplate.
And I got this Scosche kit off the web:
http://www.audiooutfitter.com/store/NN1494B.html
But the thing is, the aftermarket head unit doesn't FIT THROUGH the openings in this scosche bezel kit. It is clearly does not have 1 DIN sized openings. They are more like 0.85 DIN or something.
So I figure either I can load from front or from the back. If I load from the front, the head unit has to slide through. It is off by like 1cm on the width and 1cm on the height. So I'd have to dremel it up a bit to get the head unit through the scosche slot.
If I load it from the back, like if I put the bezel on AFTER the head unit is in, then the bezel goes around the head unit faceplate really snugly. And it doesn't go back very far. So then the problem becomes that the removable and fold-down faceplate cannot be folded down or removed, thus I can't load a CD..
Any ideas on what I can do? I hate to take a dremel to the scosche kit, to widen the opening a bit, but I just might have to...
Thanks,
Kevin
Old Feb 11, 2006 | 12:13 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Your not trying to put it in With the sleeve are you?
Old Feb 11, 2006 | 12:34 PM
maxcosity's Avatar
nope, not using the metal sleeve that came with the head unit. That didn't seem to want to be mounted anywhere, so I just screwed in the head unit to the factory holes.
What bezel did you guys use? And does your aftermarket HU have a flip-down/removable faceplate?
Thanks!
Old Feb 11, 2006 | 01:47 PM
nismos14's Avatar
§è~® f®ÈÄk
Thats odd, you'd think that scosche would know the difference between a full din and a tweaked size.... What head unit are you running? Are you sure your not using a 1.5 din unit?
Old Feb 11, 2006 | 03:38 PM
maxcosity's Avatar
It only misses by like 1cm or so all around.. If it was 1.5 DIN, it would be much larger..
Anyone else have the scosche kit?
Old Feb 11, 2006 | 05:25 PM
djfrestyl's Avatar
Suspension Yoda
a CENTImeter all the way around? or a MILImeter?
big difference my friend....
Old Feb 11, 2006 | 06:34 PM
maxcosity's Avatar
I think it's about a centimeter. Maybe 5mm. I didn't measure it. It's DAMN close, but not quite.
No one else is using the scosche kit? What about the Metra kit??
Old Feb 11, 2006 | 09:35 PM
nismos14's Avatar
§è~® f®ÈÄk
Thats weird cuz even in the pic it looks like it'd be big enough.
Old Feb 11, 2006 | 09:37 PM
Pearl96Max's Avatar
I tend to avoid Scosche due to fitment issues. Metra is definately the better choice.
IIRC you do need to mount from behind though.
Old Feb 12, 2006 | 09:52 AM
02maxxxSE's Avatar
Yea but from that picture it looks like the Scocshe looks much better than the metra. Metra looks awful.
Old Feb 12, 2006 | 10:19 AM
kpr10is's Avatar
Hate to say it, but installer error?.... Heres the one and only Scosche kit Ive done.
And I didnt touch a dremel or trim the kit in any way. The mounting holes were off, so I had to redrill, but that was it.
Old Feb 12, 2006 | 02:56 PM
maxcosity's Avatar
Damn.. That sure fits nicely. I guess my janky CD unit is not as accurate in it's 1DIN claim as the Alpine head units are, eh?
Installer aside, the head unit FOR SURE won't fit through either of the 2 openings without shaving off 1/8" per side and 1/8" from the bottom.
Old Feb 12, 2006 | 03:20 PM
kpr10is's Avatar
What head unit are you installing? The one above is a Pioneer.
1/8 inch on every side sounds huge. Theres no way its off that far. You sure the trim ring is off of the chassis itself? Something has to be wrong.
Old Feb 12, 2006 | 03:21 PM
Pearl96Max's Avatar
Definately something wrong here, as Ive never seen a HU Not fit, regadless of what kind of dash kit it is.
Old Feb 12, 2006 | 03:42 PM
PandaXpress's Avatar
provide some pics and im sure we could help? just a thought
Old Feb 12, 2006 | 06:17 PM
maxcosity's Avatar
Yeah I was going to snap some pics, but I didn't, sorry.
I ended up rigging up this pretty tite router (not like Juniper or Cisco, but like to route something out) with my dremel and the circle cutter attachment jig. So it snaps on from the bottom of my workbench. Then I basically just moved the bezel's interior down the guide and shaved off 1/4" on the sides (I measured and it was 1/4" that I needed!!) and 1/8" off the top. It fits snug as a bug now.
I guess the HU I got was oversized slightly, but it for sure was no 1.5DIN. That would have been WAY obvious, and not 1/4" off on the sides, 1/8" on height..
So anyways, thanks for all the info guys. If nothing else, you were my morale support through having to hack my Scosche bezel up with a dremel..
Later!
Old Feb 12, 2006 | 06:34 PM
kpr10is's Avatar
Still havent said what head unit you are installing...
Old Feb 12, 2006 | 08:56 PM
maxcosity's Avatar
Don't laugh but...
Durabrand CD/MP3/XM Player from Wal-Mart
http://www.walmart.com/catalog/produ...uct_id=3639257
It isn't that bad though. It sounds clear, and gets plenty loud w/out an amp, and plays MP3s so...
I am selling the Maxima and needed to put something less crazy in there (was a DVD/Touchscreen/Computer setup which I'm parting out and selling)...
Old Feb 12, 2006 | 09:18 PM
Pearl96Max's Avatar
and you Did take that silver trim bezel off correct?
Old Feb 12, 2006 | 09:32 PM
kpr10is's Avatar
lol same thing i asked...i doubt it
Old Feb 12, 2006 | 09:37 PM
Pearl96Max's Avatar
Kevin...most likely he didnt. I cant see for the life of me ANY radio not fitting...and you know this as well.
Old Feb 13, 2006 | 09:51 AM
nismos14's Avatar
§è~® f®ÈÄk
Thats too funny
Old Feb 13, 2006 | 10:45 AM
maxchef's Avatar
Hey Don, if my memory serves me correctly.....i dont think that the ring comes off. I sorta remember putting one in a friends car and then taking out a week later because i got fried. I da no!
Old Feb 13, 2006 | 12:21 PM
kpr10is's Avatar
Impossible my friend.
Old Feb 13, 2006 | 01:13 PM
maxchef's Avatar
Not really....but it was just an asumption....the bezel and the frame of the face plate that the face plate swivels on may all be one piece, i have seen it before but cannot recalect where...who knows.GOOD LUCK BUDDY!
Old Feb 13, 2006 | 10:02 PM
maxcosity's Avatar
OK, hold on a sec guys, I need to jump in here and dowse the flames..
I *DID* take off the faceplate, although it doesn't stick out at all, and I *DID* take off that silver trim bezel.. I mean, DUH. I've done this once or twice before..
I should measure the damn thing just to put an end to this, and prove they are lying when they say it is a 1DIN unit, but I don't care, the dremel/router did the work nicely, and its in. I'm not going to **** with it anymore just to prove they are morons over there at "Durabrand" and that is why they have the cheapest CD player at wal-mart...
But whatever, this nightmare is behind me..
Kevin + Dremel: 1
Scosche bezel: -1
"Durabrand" CD player: -10000 just for pissing me off!
Old Feb 14, 2006 | 04:59 PM
djbonsu's Avatar
does the schosce din kit color match the console in the 02-03 max???......
Old Feb 16, 2006 | 05:21 PM
maxcosity's Avatar
kind of, damn sure close, but I have the Ti edition, so perhaps my A/C vent housing is a diff color than yours. The scosche kit does not have a nice finish but a piece of 500 grit sandpaper and some nice glossy clearcoat help.
Old Feb 16, 2006 | 05:23 PM
slickrick's Avatar
check the TV pic in this thread...
Old Feb 16, 2006 | 08:34 PM
Pearl96Max's Avatar
I think Im gonna have to order a Scosche kit and one of these HUs just to see the issue here. I still cannot believe any radio "not fitting"
Old Feb 16, 2006 | 08:52 PM
nismos14's Avatar
§è~® f®ÈÄk
That radios pretty cheap at wally world. On a side note I'm hungry....
Pearl96Max's Avatar
go eat and bring me food.
Old Feb 16, 2006 | 08:55 PM
nismos14's Avatar
§è~® f®ÈÄk
Haha, what you want?
Old Feb 16, 2006 | 08:59 PM
nismos14's Avatar
§è~® f®ÈÄk
Actually didn't I bring you a sub once when I worked at subway?
Old Feb 16, 2006 | 09:00 PM
Pearl96Max's Avatar
food fool, I dont care.
Old Feb 16, 2006 | 09:03 PM
Pearl96Max's Avatar
Yea, so get me another !!
Old Feb 16, 2006 | 09:08 PM
nismos14's Avatar
§è~® f®ÈÄk
Haha... damn I went there once since I got back.... that place is not the same anymore. And their closed now
Old Feb 16, 2006 | 09:33 PM
djfrestyl's Avatar
Suspension Yoda
And THEY'RE closed now
And grammar ownz you.
Old Feb 16, 2006 | 09:48 PM
Pearl96Max's Avatar
pwned
I was gonna let him slide on that one.
Old Feb 16, 2006 | 10:05 PM
nismos14's Avatar
§è~® f®ÈÄk
Looks fine to me
