Sealing the back of door mids enclosure on a 98?
I swear I have spent alot of time searching for this info. Maybe I have poor searching skills.
I have a 98 non-bose and the plastic Mid mounting enclosure in the door is open on the lower back side. Can someone help with the best way to seal it off. Plastic?
Also the new mid woofer protrudes out about 1 cm past the mounting. Will this come close to touching the factory grill in the door panel?
Thanks alot for any help.
then further sealed up with some raamat...
OK now for the other question, I'd strongly suggest forget about the plastic mounting that the original speakers came with and make some MDF rings. The great thing about the 98's is that there's room for a double 3/4" MDF ring (1.5" ring) if you're using a big speaker and need extra depth, like I did for the big 8's....
Gosh now that I think about it...it was a LONG time ago when I got rid of the plastic baffle that the stock speaker was mounted to, but now I'm thinking I remember it having a back to it, right behind the speaker. If sealing that is what you're asking about, forget it. Get rid of it. You want your midwoofer to have lots airspace, like your whole door. Seal off and deaden your whole door, use an MDF baffle, and you'll be good to go....
Originally Posted by AscendantMax
don't we all...
Yea but Gordon, most people come through.
Parag hardly ever does, cause he can never make up his mind on what he wants..
Originally Posted by rob15job47
Money whats that?lol jk...but im plannin on doing thisto my 95 Gle soon bcuz im deading the whole car, im doing the front doors. would u reccomend liquid or mat or both???and should u deaden the entire inner door and outter?
Definately mat cause it's great at covering little holes and for me, less messy. Both would work for deading, I'm sure (weight is weight). I've used both and definately prefer mat. Consider raamat from raamaudio.com or second skin.
yeah on that plastic thing, let it go. if you cant cut the rings get with don or someone, hell order em off ebay. I used em for the first month just to test out between the speakers I had on hand and trashed them as soon as i finished.
And steve, they have the whole bottom open almost like its in there as an umbrella.
Thats the problem...lack of money.
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
Slamrod
Aug 10, 2015 12:33 PM
I wanna put 8's in my doors!
