2002 max audio questions....
I want to take out the factory sub and put something else in the trunk with an amp, but I dont want to get rid of the factory head unit. First does the factory bose have a RCA outputs? if not than is there a way to hook the new amp up with the wires that go to the factory sub? Thanks any suggestions are appreciated. Greg
Originally Posted by BeSeenWithGreen
Near center city, thanks for the info...will get that kit for $100.
Whoa, Please do not spend $100 on an UN NEEDED "kit". It is an absolute waste of money when a cheap set of RCA leads can simply be spliced in.
I'm not sure where I would need to splice them into... Is there a write up?
42nd and baltimore, huh? Not far from Hospital of the Universiy of Pennsylvania where I work.
I spliced into the harness going into the amp in the trunk. I got the wiring colors off the Owens Family site. Anyone know the link? I ran power from the battery and ran a short ground wire. ( don't use the factory ground in harness, you'll get nasty interference) Everything wire you need to do 1 or more amps is in that harness including the remote wire for the amp on/off.
SUPER EASY INSTALL!!
Good stuff
I got to check out that site. ThanksWe can meet up sometime when it gets warmer outside, I aint doing any mods in this cold
This should be it... http://maxima.theowensfamily.com/
BrandonCause
Sep 20, 2015 10:20 PM
Justin Kroll
Sep 2, 2015 11:06 AM
