Box geometry question...
Old Mar 3, 2006 | 12:19 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
For running a sealed enclosure, is the most important parameter that it be sealed and simply have x.x cuft? Or will the geometry of the box play a role in its response?
Old Mar 3, 2006 | 03:14 AM
BBOYSTEVIE's Avatar
Back from Hibernation
As long as the box is solid/well braced and has the right airspace you're OK. Geometry shouldn't matter.
Old Mar 3, 2006 | 05:04 AM
mendon99's Avatar
tastey wheat
otherwise all those custom boxes would prolly sound like poo.
though i've never heard one.. id like to
Old Mar 3, 2006 | 07:07 AM
slickrick's Avatar
ya unless you plan on running your sub above 200hz you are fine. standing waves are not an issue with a typical car audio install.
Old Mar 3, 2006 | 07:41 AM
White Shadow's Avatar
Still chugging along...
Rigidity to eliminate flexing and being properly sealed are key. A sealed enclosure application that leaks sounds like ***. An enclosure that's slightly too large for your application can easily be fixed by adding extra volume inside the box by gluing some MDF scraps inside to decrease internal volume or better yet, you can add more bracing to displace internal volume.
Old Mar 3, 2006 | 04:51 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
how many subs?
generally the sub just needs the airspace, but angling can play into it when its completed. More than a single sub i would start worrying about angling, but a single sub setup youll be fine.
Old Mar 6, 2006 | 09:58 AM
djfrestyl's Avatar
Suspension Yoda
Or, if it's a multiple sub set up, just make sure each enclosure is sealed off from the one next to it.
Old Mar 6, 2006 | 11:48 AM
MacGyverS2000's Avatar
I'll agree with the above... except to add that extreme geometries will have an effect. By "extreme", I mean two cubic feet with two 0.95-cubic ft boxes attached by a 0.1-cubic foot channel (think like a dumbell shape). Don't laugh, I've seen it attempted. When space gets tight, people will weasel their boxes along any open path to get that magic volume. Once you go down that road, the wave interference totally destroys any advantage from going with that specific volume. Just an FYI...
Old Mar 6, 2006 | 04:04 PM
I would be looking into placing two subs into the wheelwell. I don't want to have to FG the bish, but whatever may come...
Old Mar 6, 2006 | 04:08 PM
slickrick's Avatar
ugh oh...what 2 subs? I assume 8's or 10's?
Old Mar 6, 2006 | 05:00 PM
2 x Alumapro Alchemy RX...gotta see it I can even come close to fitting them in there foist.
Old Mar 6, 2006 | 05:09 PM
slickrick's Avatar
somebody FG's 2 10" momo's into the spare tire well. I wanna see how this comes out.
Old Mar 6, 2006 | 05:22 PM
I'd LOVE to fg the whole trunk, although I think Imma just go 'stealth' route and just have them rear firing, with the distroblock, x-overs, and amps all showing on the bottom.
Old Mar 6, 2006 | 08:20 PM
clive's Avatar
100% chingon
Ideally, an irregular geometry should be used. The worst shape is a cube. This is because of resonance effects. I use a couple of different pieces of software when designing bass cabs; the last free-standing labyrinth cab I made, did +7dB at 40Hz. The trunk is plenty big enough to make an excellent bass enclosure.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
Sep 27, 2015 08:37 AM
Stagnet04
Sep 14, 2015 11:28 PM
