best distro-blocks? and battery terminals?
Old Mar 30, 2006 | 10:54 AM
mendon99's Avatar
tastey wheat
anybody have any prefrence? im thinking of getting new ones.. of both. what is everyone using?
Old Mar 30, 2006 | 10:55 AM
slickrick's Avatar
I use a RF distro block thats 4 gauge in/out fused and it works fine.
Old Mar 30, 2006 | 11:53 AM
kpr10is's Avatar
Ive always liked Stinger...for both wire and wire accessories like that. But they all do the same thing until you get into the fancy ones with voltage/amperage displays etc.
BBOYSTEVIE's Avatar
Back from Hibernation
Ok I admit it's not the most economically wise, but I love my Stinger SHDA4. Last dist block I should ever need, with blingy voltage and amperage readouts for each amp! I love it though! Eventually will get the matching battery terminals. How many amps are you running? What size wire?
Old Mar 30, 2006 | 12:00 PM
filtor1's Avatar
Stinger. I have the baby brother of the one above. Love it.
Old Mar 30, 2006 | 12:06 PM
djfrestyl's Avatar
Suspension Yoda
I have a standard Knukonceptz one. Works fine, no voltage loss, cheap
When it comes to distribution, metal is metal, whatever conducts, works.
Old Mar 30, 2006 | 12:09 PM
BBOYSTEVIE's Avatar
Yeah I'll agree with that too. If you're on a budget and need a "commonly made" sized dist-block, get something cheap. I really do like the Stinger if you wanna drop a little extra coin though and have something that looks cool.
Old Mar 30, 2006 | 12:11 PM
djfrestyl's Avatar
Suspension Yoda
I'm even thinking of just using a coupler, or, eff it, just solder the 0 to the 4/8
Old Mar 30, 2006 | 01:29 PM
nismos14's Avatar
§è~® f®ÈÄk
Use a bolt and ring terminals .... lol.
Old Mar 30, 2006 | 09:29 PM
mendon99's Avatar
tastey wheat
thanks guys. bboy, that one looks pretty cool...
im running 4 awg right now, but i might switch to 1/0 in the near future... 2 amps, neither of witch i have right now, but i will soon, im just getting prepared..
so stinger for battery terminals also? any others? ive seen tons on peoples cars all over the forum.
Old Mar 30, 2006 | 09:37 PM
TheBigDu's Avatar
I second this. I had very basic Stinger blocks when I had 4 AWG wire. I thought about buying larger ones when I upgraded to 1/0, but Don suggested just using a coupler instead. Stinger actually calls them barrel splices, so I guess that's the techincal name, but this is what they look like:
Definitely the cheapest, easiest, and probably quickest way to join the wires. I have one 1/0 going into one side and two 4 AWG going in the other. Obviously make sure you use the included sleeve and a bunch of extra electrical tape, because if you're using the coupler for the pos. and it touches the body/chassis..... you =
Also, if you're even considering going 1/0, do it now and save yourself the hassle later. Upgrading wire isn't fun and it's not something you should be doing twice. You'll probably save money in the end if you just get the big stuff now.
EDIT: Sorry, I must've missed where you said "i'm running 4 awg right now"..... So you're already where I was a few weeks ago when I finally said F it and went for the 1/0. But make sure if you get 1/0 that you do the Big 3 upgrade also. Otherwise, you're wasting your money as the stock Maxima wire is only 4 awg (IIRC). Or at least upgrade the battery to ground wire.
Good luck!
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
