why do the fuses keep blowing?
Old Apr 2, 2006 | 01:50 PM
sk24iam's Avatar
My friend has (2) 2 channel kenwood amps hooked up to (2) type r's. On one of the amps the two 30a fuses keep blowing. What could be causing this?
Old Apr 2, 2006 | 03:15 PM
AscendantMax's Avatar
could be a short somewhere. trace all the lines to see if they're secured. also check if the speaker wires themselves are touching each other (inside and outside the box).
Old Apr 3, 2006 | 07:46 PM
Majestic303's Avatar
Did this JUST happen all of a sudden, after an install, or did you wire the subs differently? Definitely start with AscendantMax's idea though, could possibly be something that simply
Old Apr 6, 2006 | 02:27 PM
sk24iam's Avatar
I chnaged the power wires with the amp that was working and it still blows so it must be a problem with the amp right?
Old Apr 6, 2006 | 02:35 PM
bigmike8771's Avatar
also check to make sure the subs arent wired in a ohm the amp cant handle.
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
Noela
Sep 26, 2015 08:22 AM
