Wrong box killing sq?
Old Apr 7, 2006 | 04:48 PM
Max_N_Action's Avatar
hey i have my eclipse SW8102.4 10 inch sub in a crappy best buy q logic single tiny box.... my bass sounds like crap..... only thing that sounds good is rap but when it comes to rock it just sounds like an earthquake.... i cant hear the kick all i hear is delayed deep bass.... could anyone tell me what kind of box i should use or where i can get a cheap one built. i could build one if i knew the measurements to use.....this is the subs specs....
Santoprene Surround
Aluminum Cone
Dual Mirror-Image Spiders
Aluminum Voice Coil Former
"Bottomless" Design
Aero-Vented Pole Piece
Cast Aluminum Frame
Double-Stacked Magnet
Small Sealed-Box Enclosure
Continuous Power Handling: 500W
Music Power Handling: 1,000W
New Dual Voice Coil (SW8100DVC)
QCA (Quick Change Assembly)
Fs: 22Hz
Qts: 0.41
DCR: 3.1 Ohms
Vas: 2.94 cuft
Xmaxone way) 1.20"
Old Apr 7, 2006 | 05:07 PM
djfrestyl's Avatar
Suspension Yoda
What are your amp settings at?
You have the measurements...
Old Apr 7, 2006 | 05:14 PM
slickrick's Avatar
what is the internal volume of the current box?
Old Apr 7, 2006 | 05:15 PM
tell u the truth i dont know wat their set at. i have tried every possible setting and it still sucks. my amp is an audiobahn like a800t or some thing.... its crap ino.
ino i have the volume and stuff that i need for i dont know how to convert that into like length width and height form....
Old Apr 7, 2006 | 05:20 PM
slickrick's Avatar
bcae1.com click on #110 that will help.
Old Apr 7, 2006 | 05:22 PM
dont exactly know wat u mean by internal volume but it says .65cuft.....which now that i think about it is no where near as big as it should be.... but will that kill the sound?
Old Apr 7, 2006 | 05:25 PM
djfrestyl's Avatar
Suspension Yoda
Yes it would. If it's sealed your sub is effectively suffocating.
Old Apr 7, 2006 | 05:31 PM
so should i build a ported box or just the right size sealed box.....
by the way i just have to mention that the red sox are winning 11-0 right now.... hadda throw that in for those that care lol
Old Apr 7, 2006 | 05:32 PM
slickrick's Avatar
I'd build a nice big sealed box...
Old Apr 7, 2006 | 05:39 PM
i think i shall.... im also using an 8g wiring kit.... since the sub is 500 rms and "supposedly" getting close to that with the amp would upgrade the wire have any benefits.... as you can tell i took the cheap way out of everything and now im sick of crappy bass
Old Apr 7, 2006 | 05:40 PM
slickrick's Avatar
I would upgrade to 4 gauge but more importantly make a box thats air tight and the proper size.
Old Apr 7, 2006 | 06:29 PM
AscendantMax's Avatar
small sealed box, and yet boomy bass response? check the xover frequency on your amp. it might be set a little too high.
Old Apr 7, 2006 | 06:36 PM
yea.... i need to find someone in the rhode isalnd area to meet with me and listen and help me..... any volenteers?
Old Apr 7, 2006 | 06:40 PM
hmm, it's easy to check. do you know the exact amp model you have? we can coach you to check from here if you know the model.
Old Apr 7, 2006 | 06:48 PM
its the audiobahn (crap ino) a8002t.... i have a jvc 5100 (the one that plays dvds) and im using the bose speakers for now.... my problem is that i want the kick to be heard more so than it is.... all that comes out of my subs is like a delay kick and insane bass.... as i said for most rap songs it sounds good but i dont listen to just rap
Old Apr 7, 2006 | 06:57 PM
alrighty...see "x-over" on the left part of the amp? set that to LPF. then on the dial right to that, is the **** to adjust the x-over frequency. where do you have it set to? turn that dial to about halfway...which is roughly 80hz.
Old Apr 7, 2006 | 06:59 PM
NightRider's Avatar
I would reset the gains and crossover frequency. Its probably too high. Also if you have a bass boost setting, set it to zero.Get some polyfill if you haven't already and stuff that box.
Old Apr 7, 2006 | 07:02 PM
polyfill won't help with punchy response...might actually make the situation worse by actually augmenting boomy bass response. smalled sealed enclosure should provide a nice punchy output. only thing i can think of is the xover is set way too high.
Old Apr 7, 2006 | 07:03 PM
ok ill try this.... polyfill? lol care to elaberate
Old Apr 7, 2006 | 07:05 PM
basically pillow stuffing. when used in a sealed box, it tricks the sub into thinking it's in a larger box, helping with the lower bass output.
Old Apr 7, 2006 | 07:09 PM
slickrick's Avatar
it helps the sub sleep at night so it can be rested the next day to perform well.
Old Apr 7, 2006 | 07:14 PM
djfrestyl's Avatar
Suspension Yoda
Bwahah. Having fun?
Old Apr 7, 2006 | 07:27 PM
any house hold items i can use in there instead.....
Old Apr 7, 2006 | 07:28 PM
slickrick's Avatar
its like $2 a bag at walmart or rip apart a pillow you are using now.
Old Apr 7, 2006 | 07:33 PM
lol.... alright.... ill give it a try
Old Apr 7, 2006 | 07:34 PM
slickrick's Avatar
do it...it does work but don't expect miracles.
Old Apr 7, 2006 | 08:37 PM
WhiteMaxima9600's Avatar
i have the same box from worstbuy, it's .65 but mine is dual... add the polyfill cause it does help a slight bit.. BTW what x-over freq. do you guys recommend as a "base" setting or does it just depend on the sound your looking for?
Old Apr 7, 2006 | 08:39 PM
depends on your setup and how well it blends with each component. i have mine set at 80. no point IMO for the sub to play any higher where a decent component set should be able to reproduce.
Old Apr 7, 2006 | 09:23 PM
yeah i agree, have mine set around 90-100hz
Old Apr 7, 2006 | 10:05 PM
djfrestyl's Avatar
Suspension Yoda
Just out of curiosity...why so high?
Old Apr 7, 2006 | 10:07 PM
yeah, 100 hz a bit high imo...
Old Apr 7, 2006 | 10:11 PM
slickrick's Avatar
80hz is a good setting.
Old Apr 8, 2006 | 12:31 PM
filtor1's Avatar
I have mine set at 100. I find that I like the sound better. It may be me, but I have never had anyone sit in my car and say they could even tell.
Old Apr 8, 2006 | 12:33 PM
filtor1's Avatar
Rich, could you tell I was set that high?
Old Apr 8, 2006 | 07:00 PM
slickrick's Avatar
No and I honestly don't believe you. JK, however I believe your subs can handle it with ease. Next time you roll by I wanna really listen to see if I can tell.
Old Apr 8, 2006 | 08:49 PM
filtor1's Avatar
Will do. Maybe Monday after class.
Old Apr 8, 2006 | 09:46 PM
I dunno seemed like a good place to start, maybe i'll go down to 80hz with the new subs.... I don't like that high, vibrating my trunk bass anyway.
Old Apr 8, 2006 | 10:01 PM
from my experiences...low freq does a hell of a lot more flexing on car panels thann higher bass frequencies.
BobTX10
Oct 7, 2015 08:43 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
bigfrank
Oct 1, 2015 12:51 PM
Sep 27, 2015 08:37 AM
