Wiring In Series....???? Dvc 10"
Old Jun 14, 2001 | 07:44 PM
metallic97gxe's Avatar
Master Will
I have a DVC Memphis Power Bass 10" Sub......it is 4ohm per voice coil in impedance I will be getting soon a Memphis Power Bass amp and I am going to run it bridged mono for 4ohm how do I wire my sub to be 4 ohms and it is DVC 4ohms...each...thank you I need step by step instructions....
Old Jun 15, 2001 | 06:25 PM
Micah95GLE's Avatar
You cannot achieve a 4-ohm load from two 4-ohm coice coils. You'll have to get a different amp. Get a Class D monoblock that is 2-ohm stable.
Old Jun 16, 2001 | 11:02 PM
CanuckAMP's Avatar
Micah is right. You cannot achieve a 4 Ohm load with that sub unless you only wire up one voicecoil. I've seen this done before though I wouldn't recommend it. It will work but you will get less travel (Xmax) out of the sub and thus less bass output. Your best bet is to get a Memphis Studio monoblock amp to drive this sub, the ST-500D would be perfect.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
