help I NEED AN AMP TO RUN 2 DIAMOND AUDIO TDXS?
Old Apr 17, 2006 | 08:43 PM
REYMAX77's Avatar
ok auto maniacs! Ok i have 2 diamond audio TDXs 2ohm im redoing my system i need an amp thats atleast 1600 rms. what do you guys recommend. i was runing 1 diamond audio 1200.1 but it was not enough something good at a good price!
Old Apr 17, 2006 | 08:47 PM
slickrick's Avatar
diamond d3 1500.1 from Don.
Old Apr 17, 2006 | 08:52 PM
1996blackmax's Avatar
Man 1.2 Kilowatts not enough.........
Old Apr 17, 2006 | 09:00 PM
REYMAX77's Avatar
yeah i think i need something more powerfull! my d5 1200.1 shutting off when i had it da vol too high.
Old Apr 17, 2006 | 09:02 PM
slickrick's Avatar
this has nothing to do with the amp...it is how it is setup.
Old Apr 17, 2006 | 09:09 PM
REYMAX77's Avatar
well the amp was set to a 1ohm so a total of 1200 rms.its a mono amp so how else would i set t up. but each sub goes a min of 800 rms
Old Apr 17, 2006 | 09:30 PM
Sounds like your gains were probably not setup properly.
Old Apr 17, 2006 | 09:49 PM
REYMAX77's Avatar
Well I Messed Around With The Gains But No Still Had A Problem, So I Got Rid Of The Amp And Now Need A New One. What Do You Guys Think About Ma Audio,hifonics,powr Acoustiks, Or Orion Amps The Have Some Nice Mono Amps Over 1800 Rms?
Old Apr 17, 2006 | 09:50 PM
slickrick's Avatar
how much are you selling this DA amp? I'll take it for $100.
Old Apr 17, 2006 | 10:02 PM
REYMAX77's Avatar
Da Amp Is Sold Alreadyand Got $300 For It!
Old Apr 17, 2006 | 11:45 PM
Pearl96Max's Avatar
I tend to get a bit irritable
The D5 1200.1 kept shutting off due to the fact they had severe thermal issues running at 1Ohm.
Why are you so eager to go with more power? Are you readin too much into the numbers on the subs perhaps?
What alternator do you have?
Old Apr 18, 2006 | 04:51 AM
nismos14's Avatar
§è~® f®ÈÄk
Definately go with one of these brands, it will be a big improvement over teh Diamond....
Old Apr 18, 2006 | 07:41 AM
REYMAX77's Avatar
well i still have the stock alternator. i know it was taken and changed on th recall they alt. had by the previous owner. well im not to eager to go with more power just something that will hit these subs and not shut off.
Old Apr 18, 2006 | 07:45 AM
Pearl96Max's Avatar
Then your better off with a 1K watt amp anyway. High efficiency amps are your friend. Youll never see much more than that. It defies the laws of physics to do so.
Old Apr 18, 2006 | 07:57 AM
REYMAX77's Avatar
ok so what would you recommend!!
Old Apr 18, 2006 | 07:59 AM
Dasyce's Avatar
wow, a DA 1200.1 wasn't enough? maybe you hearing is cutting out?
Old Apr 18, 2006 | 08:14 AM
filtor1's Avatar
I can tell you this. I have a D6 1500.1 on my pair of TDX 12"s and it isn't enough. These subs are still underpowered. If I had to do it all over again, I would have done a D61000.1 or a D61500.1 on each sub. The latter is def ovekill. Don't get me wrong, it gets down with the one amp, just falls a bit short of their capablities.
Old Apr 18, 2006 | 08:16 AM
Pearl96Max's Avatar
depends on your budget. Your local to me, so the possibilities are endless...
Old Apr 18, 2006 | 08:17 AM
Pearl96Max's Avatar
Gibi,
Unlike yours, it sounds like he had a first gen D5, which had a slew of thermal issues.
Old Apr 18, 2006 | 08:18 AM
Pearl96Max's Avatar
Thats cause your a basshead.
Like I said earlier, high efficiency amps, with decent power is more than enough. Dont ya remember I used to run these?
Old Apr 18, 2006 | 08:37 AM
Dasyce's Avatar
..I wish i was more local..
Old Apr 18, 2006 | 08:39 AM
Pearl96Max's Avatar
Blah, your local enough, just a bit of a drive...
Old Apr 18, 2006 | 08:54 AM
REYMAX77's Avatar
ok Don shoot me some prices! top 3 amps to run these but wont hurt my pocket 2 much.
Old Apr 18, 2006 | 08:59 AM
filtor1's Avatar
I most definitely am.
I have a hard time remembering all the amps you have had.
Old Apr 18, 2006 | 09:02 AM
Pearl96Max's Avatar
It would be much easier to give me a budget to work within first.
Pearl96Max's Avatar
So do I.
Old Apr 18, 2006 | 09:08 AM
REYMAX77's Avatar
well im not looking to spend under $500. thats why i thinking the diamond d6 1500.1 or a couple others.
Old Apr 18, 2006 | 09:16 AM
nismos14's Avatar
§è~® f®ÈÄk
so something greater than $500? Get an arc amp... not everything is in the power ratings u know... xxk1500 would be great im sure.
Old Apr 18, 2006 | 09:20 AM
avsmusic1's Avatar
i think he might mean a max budget
Old Apr 18, 2006 | 09:21 AM
Pearl96Max's Avatar
Not UNDER $500?
Old Apr 18, 2006 | 09:26 AM
nismos14's Avatar
§è~® f®ÈÄk
Ya I'm sure he meant not over $500
Old Apr 18, 2006 | 09:27 AM
REYMAX77's Avatar
my bad! my limit is $500
Old Apr 19, 2006 | 06:14 PM
REYMAX77's Avatar
Don so did you find any amps around that price range.
Old Apr 19, 2006 | 08:43 PM
Pearl96Max's Avatar
yea I think I have a few in mind. Ill confirm tomorrow.
Old Apr 20, 2006 | 06:24 AM
PoLo's Avatar
2-Wheelin it...
just get an eclipse 7232 and call it a day.
i'm happy with mine.
they pound my TDX's very well.
Old Apr 20, 2006 | 07:12 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
xtant 1001d for each
thats what i have on mine.
Old Apr 20, 2006 | 07:27 AM
Pearl96Max's Avatar
^^^ wow look at this, two noobx post together at the same time.
welcome back fockers
Old Apr 20, 2006 | 07:49 AM
PoLo's Avatar
2-Wheelin it...
sup sup. it's spring time, means time to tweak my ish =)
Old Apr 20, 2006 | 07:53 AM
nismos14's Avatar
§è~® f®ÈÄk
Is that Noob^ 2? Whats up Doug?
Old Apr 20, 2006 | 07:56 AM
Pearl96Max's Avatar
woohoo bout damn time
