'02 Max - Custom 10" vented box almost done - pics!
This is a vented box set up for a Kicker C10 Comp. There is 1.25 cf in the main box and the port is 0.19 cf. Purchased 2 2'x4' 3/4" MDF @ Home Depot for $14 and had them kindly assist me with cutting the 6 sides (for FREE). I cut the port, terminal opening and sub opening at home.
This box is 20" wide and only 10.75" deep. It will bolt directly in between the lower frame behind the rear seat pass through which is almost exactly 20" wide using the existing bolts and some "L" brackets.
Started on this last night. Here are pics..
Originally Posted by DcMaN
i would give it a quick test hook up to confirm you ported the box correctly otherwise youll be very upset if u hook everything up nice and neat and then have to take it all out.
I'll report how it sounds hopefully today.
Originally Posted by mendon99
did you paint it? if you're planning on carpeting why did you bother paint it?
1. I wanted too.
2. When I carpet it, if I screw it up at the seams, atleast it won't be as noticeable.
Originally Posted by AscendantMax
can't really tell in the pics, but did you use wood glue at the joints? or is it only held together by screws?
Pre-painting, I added several more screws to secure it and added the caulk. The caulk is the shiny clear stuff you can see in some of the internal pictures adn the Liquid Nails is the beige colored stuff.
Originally Posted by nismos14
Look good why does that mdf look so much thicker than 3/4"
If it was a much bigger box, visually I would think the wood would look thinner.
Well, the box is finished. I test fit it in the trunk and...
...It doesnt fit!! WTF? I was off by less than 1/4". So I pulled out the dremel and cut and grinded about 1/8" off of the frame. I then touced it up w/some paint to protect it.
And here is the finished box.
I've got a 160 watt RMS Alpine 3548 (old school) running in mono @ 4 ohms right now and it sounds good. Low end bass is quite low.
I need to figure out how/where to build an amp board so I can install a Alpine V12 mono @ 200 watt RMS and a Alpine V12 4 channel amp. Until then, the F/R spkrs are running off the head unit.
The Infinity 6002i 6.5s arrived today, so I need to install those in the rear and I'll be done.
Only thing I can't figure out is Kicker recommends putting polyfil in 50% of the box only. I put about 1 lb of polyfil in the box and it barely fit. Took me quite some time maneuvering the polyfil around to create a large enough cavity to keep the vents open on the sub.
Polyfil is a hard material to measure and I hope I did it right. I might actually consider taking some out.
forget polyfill use this stuff called cascade its like polyfill. It basically seals up any possible air leaks and becomes a cement wall + Sound deadner.
Originally Posted by slickrick
polyfill is not used for that purpose...in a ported box IMO I would not use polyfill. it really only helps in sealed boxes to lower the box QTC.
aww.. Rich knows his shiet!! aww yea son
From now on before you (or any1) builds a box, make a cardboard version with identical external dimensions to see if its going to fit. The fun ive had at many peoples expense for that reason. Atleast you wernt off by much.
I remember when a friend of mine spent a week making a box only to find out he couldnt get it into the trunk. It would fit in the trunk...if he ever got it in there
Anyway the box does look pretty good, what freq is the box tuned to?
...I've got the LPF set at 75Hz on the HU out.
Kicker tech manual also states to use a 25 HZ subsonic filter set at 24db/Octave. I have no idea what this is. I am using the sub out on the head unit. Does it auomatically filter out these unwanted lows???
I think the problem here is that you don't know yoru shiet. Polyfill in a ported box is a very odd idea.
This box was completely built off of Kicker's own tech spec's. for this speaker, so...
Yea you def better use a ssf. Alpine mono amps usually have this feature.
hmm....if the tuning frequency is 42 you NEED a SSF ASAP. however, DL some test tones and see what your box is actually tuned to. start at like 35hz and go up to 45hz. when the sub is barely moving but is still loud you can get an idea of what the tuning of the box is. If this box is made to kicker specs and its for a 10", the 42hz could be right.
hmm....if the tuning frequency is 42 you NEED a SSF ASAP. .
I'll hit some local install shops to see what they have.
It all depends on how low your sub can play before it surpasses its xmax to the point were it will physically damage the sub. With a 42hz tuning freq id guess that would be somwere between 30-35hz. Doesnt the amp have an SSF on it?
I am not in the market to buy a new amp to just get a built-in SSF, so my next option is to add one.
with that little power you could get away with a 25hz filter...parts express sells them for like $30. However, seems like alot for a filter when you can get a new or refurb amp with more power and a SSF for around 120ish.
Well, here's the deal. The Alpine I am using is rated at 160 RMS, the other Alpine V12 is rated at 200 RMS. The Kicker is rated at 150 RMS, so I really have no need for more power. I already have enough. One of the reasons I bought the C10 Comp was because of this.
I'll look into the FMOD inline RCA's. Thanks for your suggestions.
didnt realize the RMS was that low...the FMOD's should be just fine.
So I found a PAC ANC-25H 25Hz Active SSF and I am looking at the FMOD passive RCA. Both are 12db/octave. Kicker tested with a 25 Hz, 24db/octave SSF. Will I notice a huge difference if I use a 12db?
If it matters, then it's a waste of money for me. I have to buy 2 FMODS per channel and a two 3db attenuators to stack the FMODs and get them to 24db/octave. At that point, a new amp would probably be less expensive.
