wHICH ONE, WHICH ONE??
Old Jul 9, 2006 | 06:29 AM
illlojik's Avatar
I C U
ALPINE SWR-1242D (SWR1242D) OR the 2ohm version??
Has a loyal fan following
Pioneer Premier TS-W3004SPL
Rediculous RMS
Basically I'm just trying to have one 12'' powered by at least a 500 bridged RMS AMP (undecided). I'm not sure what kind of box would be best for either speaker setup, Sealed, Ported, bandpass? Any opinions are welcome.
Old Jul 9, 2006 | 09:05 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I am guessing you are looking for an SPL setup, in which case I would recommend going ported.
Have you designed the box?
Old Jul 9, 2006 | 09:11 AM
illlojik's Avatar
I C U
Nooo. I'm honestly a newb when it comes to designing boxes and such. I really am looking for a single 12 setup, nothing to destroy the next car over or anything. But enough to sound clean and give a respectable "down the block thump." lol or so to speak.
I've heard a few folks rave about thier Type R's being a great sub for the money.
As for the box setup up, I guess makign my own would be the better route than buying a ready made, Qlogic, mtx, etc box huh?
Old Jul 9, 2006 | 10:44 AM
Hexon's Avatar
If you are looking for a cheap amp, just get a profile amp. The sell them on crutchfield.com.
Old Jul 9, 2006 | 12:21 PM
mendon99's Avatar
tastey wheat
you don't need to design the box, thats been done. go here, build one yourself:
http://www.caraudio.com/forum/showthread.php?t=137804
the premier will probably be louder, the alpine probably better quality. if you're just looking for SPL, then go for the Premeir, and build a nice big ported box, close to the pioneer's specs.
Old Jul 9, 2006 | 12:26 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Cant tell you whether 2 or 4Ohm til you have an amp. Otherwise youll be limited to what amps you can use. Get the amp first.
Also since apparently your looking more for SPL, Id highly suggest getting your sub from a legit dealer. Beatin the h3ll out of a sub can lead to premature failure. Its always good to have a warranty.
Old Jul 9, 2006 | 12:59 PM
maxchef's Avatar
hey don....
Old Jul 9, 2006 | 01:09 PM
Pearl96Max's Avatar
Sup Greg?
Old Jul 9, 2006 | 01:58 PM
illlojik's Avatar
I C U
Oh yeah on the legit dealer. those were the 1st site that came up when I searched for the amp. A friend of mine is going to give me one of his old amps laying around. IT's nothing to brag about but until I upgrade one I really like.
http://www.millionbuy.com/paklt9802.html << I believe thats it. Its not 2 ohm mono stable so I guess that limits me to a 4 ohm for now.
After I blow that amp up (which will prob be soon..lol), and put more audio money aside, this will give me the perfect excuse to go on a shopping spree via Don the great one. I hear you're the man to talk to in these parts.
Old Jul 9, 2006 | 02:07 PM
Pearl96Max's Avatar
If its Not 2Ohm stable, then you would need the 2 Ohm model, not the 4.
Old Jul 9, 2006 | 02:19 PM
illlojik's Avatar
I C U
(dumb question alert.. but u know what the say, the dumb question is the one not asked..) SO you're saying if the AMP is not 2 ohm stable, I should get the 2 ohm stable amp? or the 2 ohm sub?
Either case, the amp is a free and I just wanted a sub to work with it that I can also use later.
Old Jul 9, 2006 | 02:24 PM
Pearl96Max's Avatar
You need the 2Ohm version sub. Since its DVC..2Ohm in series will yield a 4Ohm load on the amp.If you did the 4Ohm version sub, then you would only have the options of 2 or 8Ohm load.
Old Jul 9, 2006 | 02:27 PM
illlojik's Avatar
I C U
ahhhhhhhh.. ok. I'm learning already. Why thank you kind sir.
Old Jul 9, 2006 | 03:37 PM
Pearl96Max's Avatar
no problem.
Old Jul 9, 2006 | 04:00 PM
illlojik's Avatar
I C U
Correction... I actually read the stats on said free amp. It IS 2 Ohm stable. Does this change the wiring options? I've decided to go with the Alpine Type R: ALPINE SWR-1222D 12 2 Ohm version if this info helps. Thanks in Advanced.
Old Jul 9, 2006 | 04:06 PM
Pearl96Max's Avatar
Then you need the 4Ohm version if it is 2Ohm MONO stable. Make sure your reading correctly and it does in fact state MONO , not STEREO.
Old Jul 9, 2006 | 05:20 PM
illlojik's Avatar
I C U
yeah I'm tripping, does say stereo. Oh well, 2 ohm sub it still is. Not that theres anything wrong with that.
