It doesn't fit...
Old Jul 16, 2006 | 09:03 PM
Black Maxima
It doesn't fit...
I spent a couple hours for the past two days making this box. It's a 3 cubic foot box tuned to 35 Hz for my Atlas 15 . I thought I would give it a try after talking to AscendantMax Friday night. I put it in my trunk and found out it doesn't fit. It only fits with the subwoofer pointing upright. I'm going to try fitting it again tomorrow. I still need to plug up the gaps in the box. I think it sounds better (as in louder and more thump) than my other 3 cubic foot box tuned to 29 Hz. Seems like it can hit more tones without clipping.
Pointless thread?????
Old Jul 16, 2006 | 09:04 PM
Black Maxima
I followed this diagram:
Old Jul 16, 2006 | 09:06 PM
kpr10is's Avatar
How so? You cant fit it through the trunk opening with the sub facing the rear? Because you should be able to fit a 17" tall box height wise, but I see how getting it in the trunk might be tricky depending on your box.
Old Jul 16, 2006 | 09:09 PM
AscendantMax's Avatar
damn, good job on the box. looks pretty good!
but yeah, trying to fit a trunk into our cars can be a b*tch. my brahma box had to go in at this wierdo angle.
Old Jul 16, 2006 | 09:18 PM
Black Maxima
It is very tricky. Definitely a two person job. A little skinny kid like me had trouble carrying it out to the car in the first place. I'll take some measurements and see what's good. My cuts were not that great. Nothing some caulking can't fit. I gave up trying to fit it because it was like 150 degrees today...
Oh and another thing. Is there a big difference between the sub pointing up versus pointing towards the rear?
Old Jul 16, 2006 | 11:03 PM
Black Maxima
BUMP to el top.
Old Jul 17, 2006 | 04:27 AM
mendon99's Avatar
tastey wheat
dammit. thats EXACTLY the box size Eclipse recommended i make for my Titanium 12.... and those were the EXACT plans i was going to use.. ARG!! wtf are the odds.
im glad you made it first though, haha.. which sides didnt fit? cna you point them out on the plan??
it may sound a bit different pointed up rather than the rear, but it would look a whole lot better if it was in the way you want it in im sure. It's probably louder a least a little bit because its a higer tuning.
how much did you spend on materials if you dont mind me asking? did you get hte 2'x4' sheets of MDF at HD or something?
Old Jul 17, 2006 | 04:35 AM
yeah, two people will definately make it easier. what side isn't going in? it should be louder firing into the rear. you barely have any space between the sub and trunk lid the way you have it now.
Old Jul 17, 2006 | 09:27 AM
Fast1one's Avatar
You cant just tilt it towards you till it lays all the way down? Get some extra hands it should fit....
Old Jul 17, 2006 | 11:29 AM
Black Maxima
The way it isn't fitting is the top edge and bottom edge are hitting the trunk openings when I tilt it to try to get it in. Seems like it's too tall, as in 17" high.
That's wierd that you need to use those box plans for your sub. It cost me $23 for the wood. I have/had screws and all other other materials needed in my basement. Do not go to Home Depot and get the sheets of MDF. It's way to expensive. I did that on my last box and I was kicking myself in the butt. Go to Lowe's and have them cut one of their big sheets. They are $20 and do not charge for cuts.
I'm going to try and refit it today.
Old Jul 17, 2006 | 12:34 PM
Black Maxima
IT FIIIIIIIIIIIIIIIITS!!!!!!!!!
Thank you so much.
It fits!!!!!!!!!!!!
Old Jul 17, 2006 | 12:36 PM
Black Maxima
It sounds sooooo good toooooooooooooooooo.
Old Jul 17, 2006 | 01:27 PM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
wow doesnt leave much room does it lol
Old Jul 17, 2006 | 01:47 PM
mendon99's Avatar
tastey wheat
...Go to Lowe's and have them cut one of their big sheets. They are $20 and do not charge for cuts.
really? you had them cut all the demensions for you? or did you have them cut a few really large pieces? thanks man.
Old Jul 17, 2006 | 02:00 PM
Fast1one's Avatar
We all told you it would sound great in a better box.......did you ever doubt us? Your welcome BTW. I knew it would fit....
That box is about as big as the one for my four assassins.....Worth giving up that space though huh?
Old Jul 17, 2006 | 02:04 PM
TAPOUT's Avatar
You will lose
You definately need more screws in that box.....You should have one every 4 inches to stop box flex.
Old Jul 17, 2006 | 02:21 PM
HitManSE's Avatar
^ Nah, the screws are there to hold the box until the glue dries. Given it was made porperly and good glue was used ive seen boxes with no screw holding it at all. If you want to stop flexing, use thicker panels & some bracing.
The glue (dependant on brand) is usually stronger then the wood being used to build the box.
Old Jul 17, 2006 | 03:52 PM
yep, the bond at the glued joint is stronger than the MDF itself.
glad it worked out for ya! looks nice in the trunk.
Old Jul 17, 2006 | 06:21 PM
Black Maxima
Thanks for the replies! Yea, it does sound way better in this box. Thank you!!!! I might put a couple more screws in, I just wanted to test everything out first. I didn't glue it or caulk it yet. There are gaps like woah in it.
I will let you know how it sounds tomorrow with the caulking.
Old Jul 17, 2006 | 06:58 PM
i would use some good wood glue andjust reuse your existing holes you have made. no need for more screws. let that sucker sit for a few hours and it'll be solid.
Old Jul 18, 2006 | 10:41 AM
Black Maxima
WOAAAAAAH My Atlas is alive again!!!!!!!!!!!!!!!!
This box sounds so much better then my old one. My eyeballs vibrate now. And I don't think it clips. I'm so excited. I caulked all the leaks last night. I'll check to see if there are any more today, then carpet it.
Thanks for the help guys!!
I will post up a video clip soon. What song should I play?
Old Jul 18, 2006 | 10:53 AM
HitManSE's Avatar
Hmmm...not LNT, everyone plays that one. Try something that will flex the windows... like Ludacris- Get back (be careful, this song gets low) or Young Joc- It's going down.
Either one should get things shaking. If you want more in your face try Lil Wyte- Oxycotten
Dont play Bass I love you though. That song sounds cool & all but drops some notes well below 20hz. Your sub wont be too happy.
Old Jul 18, 2006 | 11:15 AM
PoLo's Avatar
2-Wheelin it...
you want good bass?
play DJ Marky - The Brazilian Job - So Tinha Que Ser Com Voce [Original Lounge Mix]
Here's the yousendit. i just put it up: http://www.yousendit.com/transfer.ph...E724484FED6A56
the song is quiet up until 1:48, then a small bass drum kicks in, then at 2:08 all hell breaks loose. it's the one song i play to show people what kinda bass my sub can handle.
let me know how it sounds with it.
Old Jul 18, 2006 | 03:12 PM
Young Jeezy - And Then What
give that song a try
Old Jul 18, 2006 | 04:39 PM
autobotguy's Avatar
When I want to demo my sub, I just use a few tracks from Bass Mechanic. I love having heavy bass cause it turns my seats into custom massage seats.
Old Jul 18, 2006 | 07:44 PM
Black Maxima
Okay guys, I got a headache from driving to work...
Old Jul 18, 2006 | 07:51 PM
Fast1one's Avatar
"Leam with it, rock it" Franchise Boys....the Chopped and screwed version though....Mostly in the thirties with one note dipping down to 26....shakes like hell...
Old Jul 18, 2006 | 07:54 PM
PoLo's Avatar
2-Wheelin it...
mind telling us what song gave you the headache
Old Jul 18, 2006 | 08:43 PM
Black Maxima
EVERY SONG!!!!! I really like the bass in that song "Go Head". The new one...
Old Jul 18, 2006 | 10:52 PM
HitManSE's Avatar
Bah, your just weak
That oxycotten song will really get your head hurting if the setup is strong enough
Thanks for the DJ Marky song Marco, cant wait to try that one.
Old Jul 19, 2006 | 05:32 AM
sunten1
Thanks Aaron
Now I have to build a new box too. . . . .
Old Jul 19, 2006 | 11:05 AM
Black Maxima
You better!!!!!!!
Old Jul 19, 2006 | 09:56 PM
ShRapNeR's Avatar
my box is about same size. maybe tad smaller, it was a btch to get in. lol but i got it down now. only takes me about 10 mins. for me its alot harder to get out than to put in..
gavin68
Sep 18, 2021 12:36 PM
BobTX10
Oct 7, 2015 08:43 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
dshinn
Sep 26, 2015 08:07 PM
