Do amps and subs have to be the same brand?
Old Jul 18, 2006 | 08:17 AM
nismax96's Avatar
I have 2 10" JL audio subs in a wedge box and I wanted to buy the JL 250/1 amp, but this amp is $450 and I don't want to spend that much just for a mono amp. Do I necessarily have to have a JL audio amp for these subs? I've been told by a couple shops the 250/1 is made for the box that I have but this amp is too expensive. Can you guys give me some suggestions on what other amps I could use? My price range is $200-250.
Old Jul 18, 2006 | 08:32 AM
Wil's95SE's Avatar
我爱台湾
No you don't need to use the same brand of amp as you do subs. Contact Don aka Pearl96Max for a great deal on an amp. He will definitely point you in the right direction.
Old Jul 18, 2006 | 08:39 AM
nismax96's Avatar
Help me out Don? What kind of mono amp do you have for $200-250?
Old Jul 18, 2006 | 08:40 AM
BBOYSTEVIE's Avatar
Back from Hibernation
ditto to everything in the last post. I'd go further and say ABSOLUTELY not...you don't need to have the same brand. There's no advantage to it whatsoever unless you REALLY like JL the company, and you wont get too much support on this forum for doing that.....
Yeah Don has good stuff at good prices....plenty more options then good ole JL.
Old Jul 18, 2006 | 05:48 PM
KUBLKMAX's Avatar
well if that sub is the w7 i would say yes get the JL amp because that thing has a weird impedence. Smart marketing by JL. Other wise not they do'nt have to be the same. You don't neccessarly have to have a mono amp either. You can also bridge a 2 channel.
Old Jul 18, 2006 | 05:54 PM
descent's Avatar
im also in the market for an amp around 600watt rms and of a quality brand... can you hook me up Don ?
Old Jul 20, 2006 | 08:48 AM
nismax96's Avatar
The subs I have are two 10wo's in a pro wedge box.
Old Jul 20, 2006 | 09:37 AM
burnurass's Avatar
this is 100% true. I got screwed because of them...
I have a 12W7 just sitting here...Tried to use an ALPINE amp. NO GO. Stupid 3ohm subwoofer.
Old Jul 20, 2006 | 06:09 PM
mendon99's Avatar
tastey wheat
::shameless plug::
nismax do you want a JL Audio amp? i have a 400 watt monoblock for sale in your price range. check sig.
Old Jul 20, 2006 | 09:30 PM
BLK2BLU's Avatar
Mine are the same brand, but its only cuz I like Alpine so much
Old Jul 21, 2006 | 11:24 AM
Realtight's Avatar
just because the subs are 3ohms doesn't mean you can't use a different amp! As long as you can find an amp that is 2ohm stable with plenty of power, a 3ohm load will actually be better for the amp and actually draw more controll and dynamic headroom.
for 200$ look on ebay, Kicker's are fine amps... but if your subs are W7's, you're not going to find an amp that powerful for that cheap. Hifonics' new amps aren't bad <--very cheap so don't expect too much.
Old Jul 21, 2006 | 11:37 AM
burnurass's Avatar
somewhat true...it's trial and error. I had an alpine amp that could do 2 ohms and 4 ohms.... It would go into protect mode because of the 3 ohms. It's just easiest to get a JL amp if you get a JLW7. Just speaking from my experience...if you search on the web you'll see other people had a similar problem.
Old Jul 21, 2006 | 12:05 PM
AscendantMax's Avatar
if it's 2 ohm stable, i don't see how it won't support 3 ohms...
Old Jul 21, 2006 | 12:32 PM
nismax96's Avatar
The subs I have are the 10wo's which produce about 125w each. The sticker on the prowedge says 2ohms.
Old Jul 21, 2006 | 01:17 PM
burnurass's Avatar
it's dumb...but some amps can't do the weird 3ohm load.... Some amps can. That's why it's good marketing by JL..
Old Jul 21, 2006 | 02:05 PM
Realtight's Avatar
Ah W0's! built so many enclosures for these subs... Dude, look on ebay, plenty of good, cheap amps...
Old Jul 21, 2006 | 02:07 PM
guess what i'm getting at is how can an amp not handle 3 ohms when it can run normally at an even lower impedance.
Old Jul 21, 2006 | 02:12 PM
Realtight's Avatar
Just some honest advise here... If your amp is 2ohm stable, and can't play a 3ohm speaker... it's a piece of crap!
Just because a speaker is rated at a certain impedance, doesn't mean it's operating at that impedance... Speakers flux at different frequencies so saying your amp can't handle a 3ohm load means at isn't going to play anything with a 2 ohm impedance either...
Check out <a href="http://www.tcsounds.com/index.htm">TC-Sounds</a> new website, they're the company that makes JL audio and some of their new subs are 3ohms, it has nothing to do w/marketing.
Old Jul 21, 2006 | 02:54 PM
burnurass's Avatar
Hey no problem...I used to think that too. I understand that if it's 2 ohm stable, and 4 ohm stable..it should be running COOL at 3 ohms. It should work...but It didin't. maybe it's just alpines...maybe it's other ones too....I dont' know. I only know that the alpine amps dind't work. I have a friend, also with an ALPINE amp that had the same exact problem with a JLW7. Most people don't run into this problem cause they run JL SUB/JL AMP. No problems there.
Old Jul 21, 2006 | 02:55 PM
burnurass's Avatar
yeah I totally understand that much... but it just didn't work. Amp played other subs fine...in fact someone on the .org has my old alpine amp. Works great.
Old Jul 21, 2006 | 02:56 PM
djfrestyl's Avatar
Suspension Yoda
I'm here for the gangbang.......
In all seriousness, I witnessed burnurass's problem. Notwithstanding that the Alpine amp *may* have been a POS, it did go into protect mode even when wired correctly.
Old Jul 21, 2006 | 04:02 PM
Hexon's Avatar
Was it defective? Alpine amps are more pricey than I would've expected from an entry level company, however, their stuff should be required to WORK none-the-less. I looked at the alpine amps when I was looking for a good amp. I looked past them once I saw how expensive they got near the higher watt range. I stayed on the entry level and got a kenwood amp. I figured $280 was good for an amp that did 500w@4 ohms and 850w@2 ohms.
Old Jul 21, 2006 | 04:17 PM
1996blackmax's Avatar
I would not call Alpine amps or the company entry level.
Is there better to be had, yes, it still does not make them that.
Old Jul 21, 2006 | 06:55 PM
BLK2BLU's Avatar
10 char
Old Jul 21, 2006 | 07:18 PM
siren001's Avatar
Well I get JL all around, some car specialist say its better to stay with the same brand you can buy and amp that is made for the sub. etc. But I think its better staying same brand for show's
Old Jul 21, 2006 | 07:21 PM
djfrestyl's Avatar
Suspension Yoda
That guy is hardly a "specialist"
Old Jul 22, 2006 | 08:31 PM
I would definately agree with that.
Old Jul 23, 2006 | 06:33 AM
spark plugs.'s Avatar
Hi, I drive a Maxima.
while i have played around with many different subs, i would only use a memphis amplifier, and NO the sub and amp don't have to brandmatch
Old Jul 23, 2006 | 06:54 AM
Why? ..........
Old Jul 23, 2006 | 08:11 AM
mendon99's Avatar
tastey wheat
yeah really, why? memphis is not the only brand out there.
Old Jul 23, 2006 | 08:15 AM
because i have always been satisfied with their sound quality and efficiency and it doens't break the bank, like JL.
Old Jul 23, 2006 | 11:53 AM
burnurass's Avatar
NOpe..not defective. Worked GREAT with another set of subwoofers. Just the JL w7 giving it problems. I'm not saying you have to get a JL amp but if you want it to DEF. work w/o any surprises with the W7 then that's the way to go. First of all there are other better choices as everyone has said.
Old Jul 24, 2006 | 06:08 AM
sterlingmaxima's Avatar
should have tried the phoenix gold the made an amp that supports all the ohm loads as well and cheaper than the jl but the jl amp 1000/1 sounds amazing sence it has a ridiculous eq on the amp itself.
Old Jul 24, 2006 | 11:11 AM
Is it not just a one band parametric EQ?
Old Jul 24, 2006 | 11:17 AM
it has parametric eq
Old Jul 24, 2006 | 11:29 AM
That was what I was saying...
Old Jul 24, 2006 | 02:04 PM
sorry missed that
I am not sure on how many bads but I believe any time you state it is a parametric meaning it has more than one band that is what i was lead to believe.
Old Jul 24, 2006 | 02:13 PM
Pearl96Max's Avatar
I tend to get a bit irritable
parametric means adjustable band. If its one its one.
Old Jul 24, 2006 | 02:48 PM
3 band I just asked my friend who owns it also features the bassboost, subsonic filter, and normal lp filter
Old Jul 24, 2006 | 02:52 PM
Pearl96Max's Avatar
Bassboost is a waste that should be left alone. SS filter only has certain applications where it would apply. LP is all you need if running subs.
What 3 bands does it have?
