Weeeeening noise.
Old Jul 25, 2006 | 07:18 PM
Scooobay's Avatar
Weeeeening noise.
Ok, i installed a microvision 7 inch screen, install went fine, i even un-did my head unit and rewired everything ( Twice ) and the screen works fine. But when i have my ps2 plugged in i hear no noise but when i turn the ps2 on i hear a " weeeeeeeeeeen "-ing noise. I made sure the RCA's arent near a power source, tried 6 different grounds, i even cut open my inverter and wired it directly to the battery. anything i try im still hearing this weeening noise. wierd thing is, i dont hear it when the car is off, my dvd's and games play fine and no noise, but as soon as i start the car up i hear it.
Old Jul 25, 2006 | 08:16 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Where is the HU grounded?
Old Jul 25, 2006 | 08:29 PM
Scooobay's Avatar
i grounded it a couple places, i tried direct connecting it to the harness where it says Chassis gorund on the harness, then i tried Amp Ground on the harness ( my harness has 2 ground wires? ) then i wrapped it around what im using for the ground fo the screen, still making the noise, you think that's the prob though? i didnt get indepth with tryna ground the hu cuz it worked perfect my music plays fine and whatnot.
Old Jul 25, 2006 | 08:33 PM
Pearl96Max's Avatar
Neither of them are a ground. One is a wire going to nothing, the other is to ground the factory amp...also nothing.
You need to find a bolt and ground it to that.
Old Jul 25, 2006 | 08:34 PM
Pearl96Max's Avatar
What is the monitor grounded to??
Old Jul 25, 2006 | 08:52 PM
Scooobay's Avatar
got the monitor grounded to a bolt, but the thing is with the rca's plugged out, but the monitor on with the ps2 on and running i dont hear the noise, only one i have the Rca's plugged in, so you think i should ground the HU to a bolt, what shout i use 12 or 8 guage wire cuz im bout to go do this not
Old Jul 25, 2006 | 09:06 PM
djfrestyl's Avatar
Suspension Yoda
12 gauge for hu ground? You'd be fine with 18-20...
Old Jul 26, 2006 | 08:28 PM
Scooobay's Avatar
ok, i tried grounding the HU today, no avail, same noise, i tried 6 different grounds even as far back AS THE TRUNK, still getting that weeeeeeeening noise, anyone?
Old Jul 26, 2006 | 08:57 PM
Pearl96Max's Avatar
change your HU?
Old Jul 26, 2006 | 09:41 PM
Devchuck2g4's Avatar
what brand head unit do you have? I've had alot of problems with the rca's on customers Panasonic decks. The common solution is to ground all the RCA's to the deck itself. Try that.
Old Jul 26, 2006 | 09:50 PM
Pearl96Max's Avatar
Customers? Where do you work?
Old Jul 26, 2006 | 11:56 PM
Scooobay's Avatar
pioneer HU, i bought it at bestbuy when i worked there and got teh serviceplan since it was liek 10 bux on my discount. so i think i shall put that ***** to use come next paycheck and upgrade! i dunno what else to do, i cnat play sheeet without .. " weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeening'
Old Jul 27, 2006 | 12:30 AM
rkyat's Avatar
i feel your pain i have the same "weeeening" noise, and i havent been able to listen to music in the past 2.5 months.
Old Jul 27, 2006 | 08:58 AM
pearl96max, I goto school in Hampton VA and work in a local shop called Audio Frequency II but im from pway
PS. Im always looking for work/learn a thing or two about car audio,when I come home :-) you seem to know alot.
Old Jul 27, 2006 | 09:37 AM
bigmike8771's Avatar
i once had this same noise coming from my pioneer unit, i found that if you take a very thin piece of wire and stick it inside the rca's where they connect to the HU outputs, and take that wire and ground it to the radio chassis it took my noise right out.
Old Jul 27, 2006 | 09:39 AM
djfrestyl's Avatar
Suspension Yoda
Make sure it doesn't touch the middle pin...but ghetto rigging FTW.
user 11122324
42
Jul 18, 2022 03:35 PM
rbarnes
Dec 31, 2015 06:29 PM
05RLS2
Sep 27, 2015 09:24 PM
foodmanry
Sep 24, 2015 12:02 PM
