Where to run the pwr wire?
Old Jul 29, 2006 | 07:22 AM
JEXTEL's Avatar
I have a 4th gen and found a spot to run everything expect the pwr wire, where did you run yours?(through the firewall)
Also where did you ground your amp, I think i can use the tire track but not sure.....
Old Jul 29, 2006 | 07:59 AM
99grnmaxgxe's Avatar
The tire rack will work fine, just sand it down to bare metal, as for the power wire, there is a spot to drill under the steering hub in the engine bay.
Old Jul 29, 2006 | 08:06 AM
djfrestyl's Avatar
Suspension Yoda
If you look under your steering wheel you will see a removable panel (it's diamond shaped) Drill there.
Old Jul 29, 2006 | 09:42 AM
adampit's Avatar
i grounded to the seatbelt in the back seat
Old Jul 29, 2006 | 09:51 AM
JEXTEL's Avatar
Thanks guys Im going out to check it out.....
Old Jul 29, 2006 | 11:26 AM
Hexon's Avatar
I have 2 power wires drilled under the steering hub, Then I just pulled them over to run them under the kicks and under the carpet. I have my grounds on a bolt that was placed in the upper left side of the trunk. Everything was sanded down first before grounding though.
Old Jul 29, 2006 | 12:55 PM
DcMaN's Avatar
Since im automatic and dont need the clutch plate, i drilled through that to run the 0 gauge power wire in. As for the ground Remove the bottom half of the seat and sand down one of the seat belt bolts, that is the best spot for a ground as it is thick metal.
Old Jul 29, 2006 | 02:26 PM
JEXTEL's Avatar
thanks guys I got everything install for the pwr and ground but need alittle help with the radio install...
http://forums.maxima.org/showthread....48#post5138948
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
