JL VR650CSI will they fit an 03 max??
Old Aug 8, 2006 | 09:20 AM
djchinky's Avatar
Can anyone please tell me if these speakers will fit in a 2003 for the front doors??? I am meeting the guy to buy these speakers in a few hours and just wanted to make sure before i go buy it.. please does anyone know?? It said it would be a direct fit for most newer GM vehicles and most European cars..
http://mobile.jlaudio.com/products_c...hp?comp_id=127
thx
Steve
Old Aug 8, 2006 | 09:32 AM
spark plugs.'s Avatar
Hi, I drive a Maxima.
yes, they will...though, you might need an mdf ring to move out the speaker a little like i did b/c the window hits the magnet when you wind the windows down.
Old Aug 8, 2006 | 09:49 AM
djchinky's Avatar
what is a mdf ring and where can i get one? do you have these same speakers? how do they sound?
thx for ur help
Old Aug 8, 2006 | 03:02 PM
nismopc's Avatar
Rings made out of MDF board...
Old Aug 8, 2006 | 03:33 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Yes they will fit. I have the XR650 set in my '02.
Old Aug 9, 2006 | 05:38 AM
djchinky's Avatar
oh ic.. nice mdf rings.. SEmy2k2go did you need to use mdf rings?
Old Aug 9, 2006 | 02:34 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Yes, you'll need to make some like nismopc's (like I did as well) - found on my cardomain.
Old Aug 10, 2006 | 01:01 PM
blackpearle's Avatar
Glad I found this, I have the VR650 CXi speakers, guess I need to make a ring as well. Now all I need to figure out is how this factory head unit comes out, anyone here that can give me a step by step?? I'm assuming the shifter bezel probably pops off revealing a couple screws and that the panel above the radio with the 2 vents pops off as well, revealing a couple more screws. Is this right?? Just want to make sure before I try to pry on this stuff. Any help would be greatly appreciated.
Old Aug 11, 2006 | 07:38 AM
djchinky's Avatar
there is a write up somewhere.. i was lookin for it last week bit tricky to find.. but so far you are on the right path.. you will need a bit of force to get the vents off.. i found that to be the toughest thing.. also don't drop those screws.. i drop one of them and it fell in this small crack where all my shift links were.. and it would jam sometimes when shifting cuase i couldnt get the screw out.. then i found this awesome tool with a magnet to get the scews out..and voila!.. anyhow.. your are on the right path.. just need lots of force to get the vents off.. i pulled out and then up
Old Aug 11, 2006 | 07:40 AM
djchinky's Avatar
does anyone have a template to make mdf rings for an 2003 SE??? it is for my 6.5" in the front.. should i also make mdf rings for the rear 5.25 if i dont need them??
Old Aug 11, 2006 | 10:08 AM
SEmy2K2go's Avatar
Go BUCKS!!!
When you pull your OEM speakers out, you can trace around their shape, and they will match up perfectly.
captchaos
Mar 15, 2016 12:18 PM
carid
Sep 9, 2015 05:06 AM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
