Easy way to tell if a subwoofer is cooked?
Old Aug 17, 2006 | 10:14 AM
nismopc's Avatar
It is a 4ohm sub, but when I attach a multimeter to it, I get 3.5ohms.
Solobaric S10c round 10" sub. I've had this thing for several years (since new) and have never been able to get it to sound good. It's in a 0.61cf sealed box and I had 500w RMS going to it just recently. It would start to clip at high volume. Sounded like a clapping sound. I went back to my Kicker Comp C10 in a sealed 1.25cf with same amp and it sounds great.
Old Aug 17, 2006 | 10:53 AM
nismos14's Avatar
§è~® f®ÈÄk
A sub never tests at the same resistance. You can send me the solo and Ill have a look for u.
Old Aug 17, 2006 | 11:06 AM
nismopc's Avatar
That's what I was understanding, but thought at no load they would read a specfied ohm
Don't see that happening.
Think maybe I had the gains turned up too much on the amp?
Old Aug 17, 2006 | 12:13 PM
nismos14's Avatar
§è~® f®ÈÄk
It's possible. I'll pay shipping for the solo?
Old Aug 17, 2006 | 12:18 PM
AscendantMax's Avatar
definately recheck your gains. the sub won't show the listed resistance when you connect it to a DMM.
Old Aug 17, 2006 | 12:20 PM
filtor1's Avatar
First, they are very picky about the airspace. You say you have it in .61. Is that before or after sub displacement? IIRC they are to be put in .66 and no smaller. I have heard them sound great in .80. You have plenty of power, I would suggest trying to regain and build the correct box. You are choking the sub out right now.
Oh, and if it were blown, it would either scratch (vc scrubbing on the gap walls) or not move at all.
Also, it is normal for a coil to read "close" to the stated Ohm load. My TDX's, which are dual 4ohm vc's, read 3.78 on both coils.
Old Aug 17, 2006 | 12:21 PM
filtor1's Avatar
Oh and just in case your wondering, I had a pair of these in a friends truck, and had 3-12"s in my 3rd gen. I really liked them.
Old Aug 17, 2006 | 12:49 PM
nismopc's Avatar
Kicker specs state if pushing up to 350w, use 0.66cf, but if using up to 450w, use 0.60cf. I built it as a 0.61cf with a 500w rms amp and that is without subwoofer. So it actually is probably closer to 0.58cf or so. That's most likely my issue.
I'd love to get this thing working since I would like to keep as much trunk space as I can. I already custom mounted the amp into the rear driver side wheel well and put a carpeted cut out over it. Took no trunk space to do that.
Old Aug 17, 2006 | 12:54 PM
nismos14's Avatar
§è~® f®ÈÄk
They are great subs, the 15 I had used such a small box, and it really hit those low's very very well.
Old Aug 17, 2006 | 02:33 PM
filtor1's Avatar
Thta would be the route I would go. New box. Try doing a .8 cf box. I think it will suit your situation best. Let us know how it turns out.
Apr 16, 2020 05:15 AM
sliptap
Sep 30, 2015 05:57 AM
