Nothing but problems/Engine Noise
Old Sep 6, 2006 | 12:03 PM
Majestic's Avatar
Yahhhhhhh
I finally installed my screen and needed a dvd player to hook up to it so I bought a DC inverter. I hardwired it off of my switched 12v Sony deck wire and grounded it on a nearby screw. I have 17foot grounded rca audio cables going from my deck the dvd player and I get tremendous engine noise when revving. I just noticed yesterday that my "radio" mode is also doing the same thing. It doesn't happen when on "cd" mode. Is there a way to resolve this? I grounded the RCA ground wire on the bolt on the passenger seat since the dvd player is under the passenger seat and I grounded the other end in the same place I grounded the inverter. What is my problem? I think i may have done something wrong. Is the switched ACC wire to my deck a good place to get power to my inverter? The dvd player works without any problems.
Old Sep 6, 2006 | 03:38 PM
DcMaN's Avatar
probably not the best place to get acc from only because a inverter will require ATLEAST 10-12 guage in order to function properly and a radio acc is only 16-18. I would try getting a acc from the ignition harness.
Old Sep 6, 2006 | 03:46 PM
Majestic's Avatar
Yahhhhhhh
I thought about that. Think that would cause engine noise though?
Old Sep 6, 2006 | 03:49 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Well, first recommendation would be to go back to the ground points and sand them down to BARE metal. Your grounds may be crap due to the paint coating which would be inhibiting proper electron flow.
Old Sep 6, 2006 | 10:09 PM
VEvolution's Avatar
I miss my VE
Oh your getting the engine noises from your speakers too? Why does that happen?
Old Sep 7, 2006 | 06:04 AM
Majestic's Avatar
Yahhhhhhh
If it's a grounding problem then why did it only start when I added the inverter? Could it be an eloctromagnet field problem? Should I move the inverter farther from the CD deck?
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
