Window Modules with 791
Old Oct 7, 2006 | 08:37 AM
sean05's Avatar
hey guys. is there any way that I can still use the factory window modules with the 791?
Old Oct 7, 2006 | 10:44 AM
sean05's Avatar
i figured i would just post this question in here instead of starting a new thread becuase is related. With the 791 you get 6 channels. What are you guys using your extra channels for?
Old Oct 7, 2006 | 11:57 AM
kpr10is's Avatar
A 791xv on its own has nothing to do with window modules at all. 530T is DEi's window module, and yes, you can still use the factory window switches as well as the remote.
It does have 6 channels...two of which are lock and unlock. A third channel will be used for trunk pop. Assuming you are adding 530T's, a fourth channel, as well as ground when armed, will be used for windows. So you have two channels left to play with, which can be used for anything you want.
Old Oct 7, 2006 | 01:30 PM
sean05's Avatar
ahh. I see. So i need the 530T to use the windows. I thought it already had the module from the factory, or so my buddy informed me.
Also can you point me in the direction of the BCM and the NSS?
Old Oct 7, 2006 | 06:23 PM
kpr10is's Avatar
Wait. Do you have factory window roll up/down from the factory remote? If so, yes you can integrate that with the 791 without anything extra. If not then youll need 530T's. I always forget which 4th gens had em, and assumed yours didnt since 5.0 gens like mine didnt.
Old Oct 7, 2006 | 06:45 PM
Pearl96Max's Avatar
I tend to get a bit irritable
The 4th gens had it, but would only do down. The wires are at the BCM.
Will Not give..
One touch all around
Roll up upon arming
Both of which the 530T does.
Old Oct 7, 2006 | 08:03 PM
sean05's Avatar
Will Not give..
Roll up upon arming
humm.. i may be getting ahold of a 530T
Fbana41
Aug 29, 2016 12:18 PM
knight_yyz
Nov 1, 2015 01:34 PM
