Assassin 8'?
Old Oct 19, 2006 | 03:51 PM
nismos14's Avatar
§è~® f®ÈÄk
Assassin 8'?
That price sure is tempting, anyone with real world experience with them please let me know how what you thought of them.
Old Oct 19, 2006 | 05:06 PM
-Sin-'s Avatar
Have them in my 05, running two in IB mounted under the rear deck firing into the cabin and they sound awsome. However I did at one point have them in a sealed box in the trunk, could barely hear them so it depend on how you want to install it. In box in trunk not good, on rear deck love em... Oh and i have them power from a Polk Momo 300.2. I did not really seal up the trunk just plug up the holes on the rear deck with dynamate due to the fact I still need the rear seats to fold down. If I had to do it again, I would definitly buy them...
Old Oct 19, 2006 | 05:09 PM
nismos14's Avatar
§è~® f®ÈÄk
Nice, IF I were to venture towards them I would be using them IB. Anyone else?
Also, -Sin- have you used any other subs previous to these?
Old Oct 19, 2006 | 05:13 PM
1996blackmax's Avatar
What are you up to Parag....
Let me know what you want to do with the DLS subs .
Old Oct 19, 2006 | 08:39 PM
-Sin-'s Avatar
I've only had JL prior to these, always in a sealed box and bigger in size too, 10s and 12s. Overall I am happy with the assassins but they can't compare to overall volume of bigger subs. But these do sound much better in SQ than the JL.
Old Oct 22, 2006 | 07:34 AM
nismos14's Avatar
§è~® f®ÈÄk
-Sin- How would you describe the capabilities of the 8's in getting LOW, and hitting the deep sub bass that most of us are probably accustomed to?
Juan, check PM
Old Oct 22, 2006 | 08:09 AM
Just did ..... you got a PM Parag
Old Oct 22, 2006 | 08:19 AM
mendon99's Avatar
tastey wheat
heard nothing but good things from Ascentdant Audio. id go for it Parag.
Old Oct 22, 2006 | 02:02 PM
nismos14's Avatar
§è~® f®ÈÄk
Thanks all, hopefully I can find a few more responses.
Old Oct 22, 2006 | 05:40 PM
-Sin-'s Avatar
Juan, check PM
The lows are tight and quick, really nice. I was impressed with the performance especially for the price. I would pick it up again for twice what I paid. I also ran a test cd when I first put it in and if memory serves it hit 20hz but I really did not have anything tuned at point.
Old Oct 22, 2006 | 06:07 PM
mattj10's Avatar
could someone link me to these subs.. i looked but couldnt find them. sounds like exactly what i'm looking for! thanks!
slickrick's Avatar
this is the wrong forum to look for in depth reviews of anything AA except the ava 15. Those subs for the price are worth it IMO...they did decent in a comparison test some known audio heads did on ca.com
Old Oct 22, 2006 | 06:11 PM
slickrick's Avatar
http://ascendantaudio.com/assassin8specs.html
wow $50 is cheap. I like.
Old Oct 22, 2006 | 06:15 PM
mattj10's Avatar
thanks!!!!!!!
Old Oct 22, 2006 | 06:17 PM
mattj10's Avatar
wow. are they really 350 rms?
Old Oct 22, 2006 | 06:19 PM
nismos14's Avatar
§è~® f®ÈÄk
www.ascendantaudio.com/assassin8specs.html
Old Oct 22, 2006 | 06:22 PM
nismos14's Avatar
§è~® f®ÈÄk
Looks like thats the manufacture's spec but I would say in the range from 200 - 300 should be sufficient and the limit.
Old Oct 22, 2006 | 06:23 PM
slickrick's Avatar
I wouldnt run that much but they will fail mechanically before thermally. Keep the box size to spec and it should be fine. It will be just as loud with lets say 250 watts and does not need the full rms. its an 8" driver.
Old Oct 22, 2006 | 06:33 PM
mattj10's Avatar
when you say keep box size to spec would bigger or smaller be worse? or both?
Old Oct 22, 2006 | 06:43 PM
504boy17th's Avatar
So you are running two mounted under the deck. Did you have the Bose setup with the sub in the back deck or did you just add the two Assasins? How do you guys think one mounted in the rear deck replacing the bose would sound. Also replacing the bose amp and head unit with a pioneer premier. What would be a good amp to drive this sub?
Old Oct 22, 2006 | 06:48 PM
504boy17th's Avatar
8 inch subs
Are these subs free air subs and would they be good to replace the Bose sub in the back deck?
Old Oct 22, 2006 | 06:49 PM
504boy17th's Avatar
Old Oct 22, 2006 | 06:50 PM
504boy17th's Avatar
8 " Assasins
Old Oct 22, 2006 | 06:53 PM
mattj10's Avatar
ahh post attack
Old Oct 22, 2006 | 06:54 PM
slickrick's Avatar
the more airspace...the easier the sub "moves". so keep it to spec or SMALLER.
Old Oct 22, 2006 | 06:57 PM
mattj10's Avatar
ah i see so using that in place of the stock bose would be a BAD idea i presume?
>>obvioulsy with an amp and new wiring. i'm not thaat noobish
Old Oct 22, 2006 | 07:03 PM
nismos14's Avatar
§è~® f®ÈÄk
They can be used IB, Sin is using them in that form on the rear deck, and that is also the way I plan to use them.
Old Oct 22, 2006 | 07:09 PM
mattj10's Avatar
ok good haha thats what i hoping. how many watts do you think they can handle in that setup?
Old Oct 22, 2006 | 07:15 PM
504boy17th's Avatar
So would these sound decent in the back deck or not?
Old Oct 22, 2006 | 07:19 PM
mattj10's Avatar
they should be good. thats what i'm plannign on doing, but not any time too soon- you will most likely deal with some rattling, as the back deck is notorious for this so be prepared to deal with that.
Old Oct 22, 2006 | 07:54 PM
mattj10's Avatar
nismo, sin- how many watts do you guys plan to throw at them?
Old Oct 23, 2006 | 04:42 AM
nismos14's Avatar
§è~® f®ÈÄk
I already have 2 8's on the rear deck now, I know all about rattles. I will be powering these with about 180 watts rms wired in mono.
Old Oct 23, 2006 | 06:07 AM
-Sin-'s Avatar
I had 6x9 back there before and remove those, made a mount out of MDF and bolted it up. NO modifications to the rear deck what-so-ever. 1/4 mdf on top 1/4 and 3/4 in MDF below. The mdf did not span the entire rear deck only the area around the subwoofer.
Old Oct 23, 2006 | 06:08 AM
-Sin-'s Avatar
I talked to chad at ascendant and he said they would do very well in IB and they did....
Old Oct 23, 2006 | 06:15 AM
-Sin-'s Avatar
I get no rattling from the back deck, only in the rear view mirror. But I did used dynamate to the rear deck. Wrapped all wires in the rear deck and doors in stickyback felt. As well as placed the same on any items that may rattle. So no rear deck rattle, but I do have a rear view mirror that rattles, something inside i can't get to.
Old Oct 23, 2006 | 06:17 AM
-Sin-'s Avatar
I am running a polk momo 300.2 rated at 150 but birth sheets states somewhere in the 2s.
Old Oct 23, 2006 | 10:06 AM
nismos14's Avatar
§è~® f®ÈÄk
Sin do they seem like they are asking for more power at this point or is the 200ish more than sufficient?
Old Oct 24, 2006 | 08:17 AM
-Sin-'s Avatar
Well, I had it hooked up to a PG 600.1 with a birth sheet of 830s they had no problem with that. I have had the Polk maxed on gain and sub gain on the radio itself turned up for a test and I heard no signs of mechanical failure. So IMHO I feel they can take more. But 200ish is nore than enough to get it moving and was perfect for me. I also had to put bumpers on both front and back license plates due to vibration. Just remeber these are not tens or twelves.
Old Oct 24, 2006 | 08:23 AM
nismos14's Avatar
§è~® f®ÈÄk
Ya I'm fully aware, I've been through 10's 15's 12's and 8's and realize what an 8 can wilfully reproduce. My current 8's do sound great. I just think I want a little more ouput and these should do the trick.
Old Oct 24, 2006 | 08:27 AM
-Sin-'s Avatar
They will surpass the Bose 8's without a problem.
