help running wire through firewall in a 2k2
Old Oct 21, 2006 | 06:16 PM
maxspeed96CT's Avatar
The original VQ...
I was going to run my system wires today, after searching threw the firewall for about 30 minutes, i found nothing.
Couldnt find a spot to run a 4 gauge power wire throught the firewall in my 2k2.
Can anyone explain to me how they ran their wires and were??
Old Oct 21, 2006 | 06:17 PM
1996blackmax's Avatar
I drilled a hole above the dead pedal and ran the wire through there.
Old Oct 21, 2006 | 06:53 PM
mendon99's Avatar
tastey wheat
not sure if its hte same or not, but from the center of my 4th gen, where the center console lines up with the firewall (if that makes sense), look straight up, i found a hole, and drilled it out a little larger to fit my 1/0 awg. it might fit 4 awg without drilling...
theres a gromet you'll have to pull out..
Old Oct 21, 2006 | 07:42 PM
djfrestyl's Avatar
Suspension Yoda
4th gen is different.
on Juan's suggestion. But two holes??
Old Oct 22, 2006 | 03:12 AM
I was originally going to go with one amp under the driver's seat and one amp in the trunk. I thought that would be the easiest thing instead of using a distribution block under the seat, not much room under there with the amps. Especially with the 4150. It still worked out as both amps are under the seats now .
Old Oct 22, 2006 | 04:08 PM
GETukrainian's Avatar
as black max showed, there is a spot under the steering wheel where you can pull off part of the fabric and drill through the firewall without hitting anything
Old Oct 22, 2006 | 04:16 PM
nismos14's Avatar
§è~® f®ÈÄk
Is the 8 guage going to the 4150 Juan?
Old Oct 22, 2006 | 04:22 PM
Yes....
j/k
The 4ga is going to the 4150, & the 8ga to the 2100.
Old Oct 22, 2006 | 06:15 PM
nismos14's Avatar
§è~® f®ÈÄk
Ah ok lol.
Old Oct 22, 2006 | 07:22 PM
The original VQ...
thanks guys.
my 4th gen had like 3 places to put wires without drilling
Old Oct 23, 2006 | 10:31 AM
BLK2BLU's Avatar
Look under the driver side wheel. Peal back the plastic and there is a huge groment. You can fit 4-4guage wires through it if you wanted. You may have to take the left front tire off to do it, but I think its worth it.
Old Oct 23, 2006 | 12:59 PM
nismopc's Avatar
I drilled a hole in the plate covering the accelerator cable location. Since '02's are electronically driven, no cable. It's a PERFECT location to put the wire through. Just make sure to buy a rubber grommet to insert in hole so you do not damage the power wire. Very OEM like install.
Interior shot w/gas pedal removed...
Engine bay shot...
I'll post more tonight if I can with the 4 gauge power wire installed.
Old Oct 25, 2006 | 02:11 PM
The original VQ...
ran the wires today
Found a spot that DIDNT requre drilling
I couldnt use the spot 96blackmax put cause i have a clutch slave cylinder there.......
So i pulled off the plastic peice under the drivers side fender and first thing i see is the groment that the stock harness goes through, i just poped a hole into its groment and put the wire throught, It came out just above my clutch pedal.
I ran it together with this black wire loomed line
Old Oct 25, 2006 | 04:10 PM
MaxBoost925's Avatar
Drug Money
I drilled a hole to the right of my gas pedal in my 2000. it comes out in a PERFECT spot in the engine bay. Passed a 4 gauge wire through.
...didn't use a grommet though...
Old Oct 25, 2006 | 04:25 PM
djfrestyl's Avatar
Suspension Yoda
Grommets are not necessary
Old Oct 25, 2006 | 08:20 PM
The original VQ...
drilling isnt nessasry at all, just run it next to the stock harness!
Old Oct 25, 2006 | 08:56 PM
Drug Money
you can't find it on 5th gens... at least the guy who started the thread and myself... drilling FTW!
Old Oct 26, 2006 | 09:14 AM
The original VQ...
I am the guy that started this thread,
i found the harness while i was about to drill, it runs right under the drivers side fender.
Old Oct 26, 2006 | 10:23 AM
Drug Money
Yeah i noticed some wires going under the driver's side fender... but I didn't know how to get to it.
Old Oct 26, 2006 | 12:42 PM
The original VQ...
man i should of done a qwk wirte up with some pics, its easy , you gotta pop off the splash gaurd if you have one, and pull back the black plastic around the wheel well onthe drivers side.
Old Oct 26, 2006 | 12:51 PM
Trurida18's Avatar
i say u just throw him the pics....thats the way i did mine on my 2k1....i had to drill a LIL bit though because I WANTED 0/1 Gauge.....I ONLY RUN POWER WIRES ONCE...AND SPLICED IT OFF TO 4 GAUGE AT A distribution block and ran 4 gauge
Old Oct 26, 2006 | 09:28 PM
The original VQ...
ya i ran 8 gauge but im running one infinity 12"
nothing crazy
Old Oct 27, 2006 | 05:19 AM
nismopc's Avatar
nothing crazy
It doesnt matter what sub your running when your determining the gauge of your power and ground wire.
It's the amount of power your amp requires that determines it.
Old Oct 27, 2006 | 05:31 AM
Trurida18's Avatar
yea u got a point there....just becasue u may have an 700 watt RMS sub, doesnt mean your amp is providing that much power
Old Oct 27, 2006 | 05:10 PM
The original VQ...
Well i was just assuming that we all knew one infinity 12 isnt gona take alot of watts..
To be more spacific im gona be running about 200watts rms
Old Oct 27, 2006 | 06:23 PM
Drug Money
My MTX 801D runs at 250w RMS at 4 ohms... it required a 4 gauge wire.
Old Oct 27, 2006 | 08:28 PM
Trurida18's Avatar
most sub amps and sub setups, say that you should use 4 gauge wire for the mono amps
Old Oct 27, 2006 | 10:40 PM
THX's Avatar
THX
Hallelujah
I used the same exact location for my last two Maximas (3rd & 4th gen). I saw the grommet on the drivers side and wondered how to get to it. With a little extra elbow grease (have to remove the tire) I found it, best part being you don't have to drill through metal.
I'm about to install some amps in my newly bought 5th gen, I'll take some pics then if the light's good.
Old Oct 28, 2006 | 10:23 PM
Trurida18's Avatar
so is some one gonna post HOW TO GET THROUGH THE FIREWALL WITHOUT DRILLING?....becasue i for one would like to know I HAD TO DRILL AND I CAUGHT HELL,
Old Oct 28, 2006 | 10:26 PM
djfrestyl's Avatar
Suspension Yoda
There are existing holes?
Old Oct 29, 2006 | 04:07 AM
nismos14's Avatar
§è~® f®ÈÄk
Are you blind? There were pics in this thread, AND descriptions... did you not read dude?
Old Oct 29, 2006 | 06:42 AM
Trurida18's Avatar
DAMMIT MAN, IM TALKING ABOUT THE SO CALLED HOLE NEAR THE STOCK WIRE HARNESS THAT THEY WERE SPEAKING ABOUT
Old Oct 29, 2006 | 07:38 AM
djfrestyl's Avatar
Suspension Yoda
Keep talking in caps and getting annoyed with users that are trying to help you and I'm sure a mod will have no problem giving you a nice vacation.
If you pull off the wheel and move the wheel liner, there is NO way you can miss it.
Old Oct 29, 2006 | 05:41 PM
Trurida18's Avatar
why dont u go do something.............. because i typed in caps, DOES NOT signify me getting annoyed. 2nd of all if NISMOS14 had a problem with it im sure he/she would have stated it. hence case, i would apologize..... NOW UNTIL THAT TIME COMES, GO DO something other than toy around with me and threating me about some mod
BTW: i want to order one of your spare tire covers
Old Oct 29, 2006 | 07:08 PM
djfrestyl's Avatar
Suspension Yoda
Well, instead of getting annoyed, which is clearly what you did by your tone and use of capital letters, you could read, because the information is a few posts up from your original post. Pics are not necessary: remove the wheel, remove the wheel well liner, and you will see the HUGE grommet that the entire factory harness (for the entire car) comes through.
Spare tire cover: If you want one with carpet, you're going to have to wait, the carpet is back ordered. If you want one without, I can ship asap.
Old Oct 29, 2006 | 07:45 PM
Trurida18's Avatar
LIKE I SAID BEFORE, DIDNT GET ANNOYED WIT ANYTHING, THERE WAS NO TONE
TIRECOVERS:
backordered to how long?
how much without carpet?
how much with carpet?
Old Oct 30, 2006 | 06:11 AM
nismos14's Avatar
§è~® f®ÈÄk
You really need to change your attitude. You come in here wanting help and treat people who are coming in here to help you with an attitude. Clearly you only care about helping yourself, and not to the overall effectiveness of the community you've entered. You're actually lucky that any/most of us put up with the way you act when most forums would just flame you to death. We've answered your question and instead of using your intellect to figure it out you want to get all uppity about it. Give me a break.
Old Oct 30, 2006 | 10:01 AM
Drug Money
Trurida18
Here is what you're looking for in case you can't find it for yourself
http://forums.maxima.org/showpost.ph...9&postcount=20
Old Oct 30, 2006 | 12:49 PM
BLK2BLU's Avatar
^^ this being the 11th post I thought somone might ask me more about it. Oh well, I hope you all have it figured out now
Old Oct 30, 2006 | 02:45 PM
djfrestyl's Avatar
Suspension Yoda
TIRECOVERS:
Well, when you use caps, it implies something. So stop.
1. No idea how long
2. $60 shipped
3. $70 shipped
Keep in mind I'm charging you $20 for shipping, but the real cost of shipping is closer to $25. The board itself is selling for $40 picked up, $50 with carpet.
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
