Eclipse Head Unit...will it work?
Old Jun 29, 2001 | 08:35 AM
roman's Avatar
Since my car has the bose system which has it's own amplifiers....would an Eclipse head unit work?
Old Jun 29, 2001 | 08:44 AM
Whitemax's Avatar
Disco Biscuit
ANY aftermarket HU will work, BUT you must use adapters made to convert to the Bose amplified speakers.
Old Jun 29, 2001 | 10:26 AM
roman's Avatar
Eclipse isn't just any aftermarket unit...it's not amplified. Meaning it doesn't have it's own amp. Get what I'm saying?
Old Jun 29, 2001 | 01:14 PM
Whitemax's Avatar
Disco Biscuit
From my understanding, there are converters that use RCA OR line level outputs on HU's to change over to the half ohm needed for the BOSE ( Bose run at 1 half ohm). No other brand run that low meaning that for ANY aftermarket HU to work, it MUST use a converter even if they don't have an internal amp.Eclipse are no different than any other HU. Get what I'm saying?
Old Jun 30, 2001 | 01:42 AM
KlimaxSE's Avatar
I have an Eclipse head unit and I'll tell you what. I think they are one of the best head units there are. Eclipse does have its own amp by the way. They push out like 12-15w X 4. You would think that is not that much because most head units say like 60w X 4. I don't even think there is a head unit out there that will push 60w X 4. They say it because it would be the max with hella distortion. Eclipse has like 15w X 4 with clearity and purity. I always trust a company that doesnt try to pull some lying twisted bullshït! You must get the converter to throw the head unit connected to the Boss mids though. I hope I helped you a bit. Eclipse forever!!!
Old Jun 30, 2001 | 10:34 AM
PrinzII's Avatar
OG and counting...
Actually, it depends on the model of Eclipse you are looking at. Originally, I had planned to get a 4502 head unit which does not have an amplifier. Now I have a 4441 which does. Either way, it sounds pretty good.
Old Jun 30, 2001 | 11:12 AM
KlimaxSE's Avatar
my bad, the better ones do have the amp inside...
Old Jun 30, 2001 | 12:33 PM
Whitemax's Avatar
Disco Biscuit
Actually, the "better" models of different HU brands don't have the internal amp. Helps keep the signal pure, and allow more room for better D|A converters, more features, etc.....
Old Jun 30, 2001 | 01:33 PM
KlimaxSE's Avatar
I have a better model Eclipse head unit and it has the 15w X 4.
Old Jun 30, 2001 | 02:00 PM
Whitemax's Avatar
Disco Biscuit
I'm not saying you don't, but with most brands, the top end models lack an internal amp.
jerrod99_se-l
Aug 27, 2015 08:27 PM
raffivegas
Aug 23, 2015 09:54 PM
Samedi
Aug 12, 2015 01:54 AM
MikesChevelle
Aug 9, 2015 11:50 AM
kenc15
Aug 5, 2015 08:29 AM
