Complete noob in car electronics has questions.
Old Nov 22, 2006 | 01:53 PM
EnervinE's Avatar
i has college
So I just installed my new headunit in place of non-Bose audio
I got lucky and didn't screw anything up, being the first time I've touched the inside of my dash. I just twisted wires together + electrical taped all connections to make sure everything works, and it sounded excellent. Should I leave it like that, or will I notice a difference if I solder connections?
It sounds perfect, no static or anything, but I figured I'd ask the pros.
Old Nov 22, 2006 | 03:21 PM
03SE2HEAR's Avatar
Solder and shrik wrap it. As hot as it gets out here in AZ, the electrical tape doesn't work too well and solder is a more solid connection anyway. Also keep the copper from corroding.
Old Nov 22, 2006 | 06:21 PM
djfrestyl's Avatar
Suspension Yoda
+1
If you don't solder it, at least use crimp caps or butt connectors.
Old Nov 23, 2006 | 09:14 AM
mendon99's Avatar
tastey wheat
crimp caps ftw... quick, easy
Old Nov 23, 2006 | 10:37 PM
jxkim's Avatar
i just installed a new unit as well. a double din. it was some hassle but soldering is highly recommended. crimping is the easy way out..
are you saying you dont have a permanent connection set? get some heat shrink wrap and a basic solder set. very easy
Old Nov 24, 2006 | 12:21 PM
ChrisDog318's Avatar
I would follow the advice of the above posters. I actually did the same thing when I installed my first deck about 7 years ago. After about 3 months the adhesive on the tape started to loosen and next thing you know, there is smoke coming from the deck. From that point on, I crimp all connections with butt connectors.
Old Nov 24, 2006 | 04:12 PM
MAX2DAMAX's Avatar
i would have to say that it depends on the quality of the electrical tape, and how you use it; also butt connectors in my opinion suck, if you dont crimp them just right they WILL come loose, so my choise is solder and shrink wrap, cant go wrong with that.
Old Nov 24, 2006 | 04:56 PM
djfrestyl's Avatar
Suspension Yoda
Even with the best electrical tape (3M Super 77+, like $3/freakin roll), I've still found that over a few months of heat in the summer, it becomes undone.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
Hawkeye61
Aug 12, 2015 06:45 PM
MikesChevelle
Aug 9, 2015 11:50 AM
